MAX GVW LBS 5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
DSO 511954:
51 = Denver CO Ford District Sales Office, where the original selling dealer ordered the truck from.
1954 = Domestic Special Order number, truck special ordered by original purchaser, not "bought off the lot."
When there is no COLOR code stamped on the Warranty Plate, the truck was painted a non standard color per the original purchasers order, making it a Domestic Special Order.
I have a 1966 F100 with no color code on the tag. Body number is 481. It is a standard cab short bed. The exterior appears to be Holly Green. The gage panel, steering column and wheels appears to be a light beige. Anyone know what color of beige was used?
I have a 1966 F100 with no color code on the Warranty Plate. Body code is 481.
It is a standard cab short bed. The exterior appears to be Holly Green (itwasn't originally).
The gauge panel, steering column and wheels appears to be a light beige. Anyone know what color of beige was used?
Welcome to FTE
The wheels and the gauge cluster have been repainted, they would have been white originally.
The steering column is beige, which is probably correct as it matches the seat upholstery. What color is the inside of the cab and the steering wheel?
If there's no COLOR code stamped on the Warranty Plate, the truck was painted a non standard color per the original purchasers order. This makes it a Domestic Special Order.
The DSO code stamped on the 3rd line-far right of the Warranty Plate has 6 digits (numbers).
The first 2 numbers decode to the Ford District Sales Office the truck was ordered from. The last 4 numbers denote a Domestic Special Order.
Since the paint was a special order, if its formula was required, the dealer contacted Ford with the 6 digit DSO. Ford looked up the order number, then passed the paint formula back to the dealer.
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
You are correct. The wheels, gage panel, bumper, grill at closer look are off white probably wimbledon white? The steering wheel and column are beige. The inside of cab is green like the exterior. Nothing has been repainted. Truck was purchased new by my uncle.
What is the beige color name or paint code for the steering column?
You are correct. The wheels, gauge panel, bumper, grill at closer look are off white, probably Wimbledon White. The steering wheel and column are beige.
H = Sahara Beige was available as an exterior color for 1966, but there's no guarantee this is the correct shade of beige for the interior.
Back then, there was no codes on the Warranty Plate that defined interior colors.
btw: I'm 5 years older than you (DOB: 9/9/1944) and in March 1965, I bought a new 1965 F100 Standard Cab 8' Styleside, exterior and interior were Wimbledon White.
The first thing I did was to repaint the wheels black, ditched the painted dog dish hubcaps, replaced them with NOS wheel covers...from a 1952 Packard.
Greetings, my '66 door tag has a G trans code. My manual says that code is a C-4 transmission. My truck is a 3 spd manual with no sign of conversion at any point. Am I misreading the code? Thanks in advance for your assistance.
Everything else on the ID tag makes sense except for the trans. code. My truck is definitely a 3 spd manual. Thanks for the quick response Bill. As I continue to restore my '66 this site has been a real help and your fingerprints are all over it. Much appreciated.
If it was assembled on a Monday or Friday, maybe the guy that stamped the codes was stewed and/or hung over, in a hurry to go "see a man about a horse," or who knows?
The letter G looks like a C and vice versa.
Couple of things: 115" wheelbase / COLOR A = Raven Black / BODY E81: E = Red Crush Vinyl & Red Cody Pattern Woven Plastic; 81 = 81B Custom Cab.
Truck assembled in Mahwah NJ .. ordered from the Charlotte NC Ford District Sales Office. Now it's residing in Blue Jayville.
Bill, funny, but you are so right about assembly plants on Mondays and Fridays. I worked in a couple when I was younger. Half the workers on Mondays were so hung over, it could be a very dangerous place. Again, on Fridays, you could find half the assembly line workers at the local barbecue house having lunch at the bar. It was very interesting when they got back on the line after lunch. Section Formans looked the other way, mainly because half of them were also having lunch at the barbecue house. Factories can be an interesting place. If your truck matches your tag, be happy.
