proportioning valve help
Old Apr 20, 2010 | 09:26 AM
lefty rodan's Avatar
lefty rodan
In my stash of parts I found a brand new brass prop/differential pressure valve that I'd consider using in my 1978 F150 to 1965 F100 disc brake conversion. It fits the 78 prop valve bracket perfectly.. I think it's an early 80's valve but not sure from what year or model truck. Hopefully ND or others might track down the number E4TA-2B524 K2A which is stamped on the part although it was in a box marked E4TZ 2B257-C. It has an electrical connection which I guess is for the pressure failure light but it does not have a bleeder valve. Thanks for your help. Lefty
Old Apr 20, 2010 | 01:26 PM
daveengelson's Avatar
daveengelson
Not an authority, my understanding is the 73-79 prop valve will work as long as it's off a front disc brake set up, a front/rear disc brake prop valve will not work. Perhaps another member will be able to determine by P/N.
Old Apr 20, 2010 | 02:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It has an electrical connection which I guess is for the pressure failure light (*) but it does not have a bleeder valve.
There are no actual Ford part numbers marked on parts after 1956, just ID engineering numbers (when applicable).
ID engineering number: E4TA-2B524-K2A = Ford part number: E4TZ2B257C .. Brake Differential Proportioning Valve.
Fits: 1984 E250 (over 8500 lbs GVW) / 1984/85 E350 / 1984 F250 w/a GWV between 6900 & 8500 lbs.
Fits: 1984 F350 2WD Crew Cab / 1984/89 F350 w/DRW.
* D5AZ2B264A .. Low Brake Fluid Warning Light Switch.
Fits: 1980/96 F100/350 F(Super Duty) & Bronco / 1980/2002 Econoline // All 1973/78 FoMoCo Passenger Cars / 1979 LTD II (not LTD) / Ranchero / Cougar / Lincoln Town Car & Mark V.
Old Nov 2, 2010 | 01:11 PM
CAPTAINMADCAT's Avatar
CAPTAINMADCAT
E4TZ2B257C PROPORTIONING VALVE
I HAVE ONE OF THESE I WOULD LIKE TO GET RID OF NEW IN BOX OEM FORD WITH SWITCH
lefty rodan
Mar 26, 2023 10:56 PM
kegger66
May 20, 2017 10:13 PM
Zorm71
Apr 5, 2017 09:21 AM
bhenders
Jan 12, 2017 09:22 PM
lafermedavid
Dec 1, 2012 06:13 AM
