Headlight hick-up...
Old Apr 20, 2010 | 09:23 AM
tardster's Avatar
tardster
Ok so I went out to start wiring up the light switch this morning, I started the rewire over the weekend. I ran into my first big hurdle... I went to remove the ****, and I've never done this before so I gave her a tug after I tried to twist it off and BAM the rod fell right out in my hand and now I cant get it to go back in. It looks like it has a spot on the end for some type of a lock washer type of thing to keep it in the housing. Anyone have ths happen to them before and is it savable?
Old Apr 20, 2010 | 09:43 AM
Old F1's Avatar
Old F1
Yep,….but only to those who don’t have a shop manual.
On the bottom of the switch there is a small spring loaded button (Julie will have a picture in her gallery) that you push in to release the handle (button and shaft) to install it just pushes in and locks like a snakes tooth (if not damaged).
Old Apr 20, 2010 | 09:49 AM
AXracer's Avatar
AXracer
If you reach up under the dashboard to the top of the switch you should feel a spring loaded button near the rear. Pressing that button releases the switch **** shaft. Since you have already removed the shaft, you might as well unscrew the trim bezel on the dash face and drop the switch out to take a look at it to see if/howmuch you might have damaged that latch. It has a keyhole shaped hole in it where the shaft goes thru the larger opening when you press the latch down and the narrower part hooks onto the slot when you release it. I suspect it will at least be repairable.
Old Apr 20, 2010 | 10:10 AM
tardster's Avatar
tardster
Ok theres no getting it to go back in so next question is does it have to be from a 55 ford truck or can i get any ford dash ignition switch?
Old Apr 20, 2010 | 11:05 AM
Old F1's Avatar
Old F1
Wake up, smell the coffee, you mean headlight switch. Right?
So this is kind of what you have ….(generic pictures……not yours),…. if you carefully clean up the notch on the rod and PUSH the button down on the switch while installing will the rod lock in? If not, you will have to by a new or used handle and maybe the switch for your model of truck! (and a shop manual)
https://www.ford-trucks.com/forums/a...1&d=1271779287, https://www.ford-trucks.com/forums/a...1&d=1271779289
Old Apr 20, 2010 | 11:08 AM
AXracer's Avatar
AXracer
you mean headlight switch?
The pull out **** type switch are pretty much universal with just the bezel and **** being different. You can likely find a replacement at your local NAPA store.
Old Apr 20, 2010 | 12:26 PM
Julies Cool F1's Avatar
Julies Cool F1
Ok there's a secret to getting that **** out. Not only do you have to push the little button on the bottom, but you have to twist the **** gently as you pull. Be sure that when you push the little button, the **** is all the way IN! Try pushing in the button and twisting to get it back in too - might work?!?
Hopefully the retainer inside the switch didn't bend or break. 55 headlight switches are ATROCIOUSLY expensive!
And yes, if you are sticking with 6 volt with OEM wiring it has to be a 55 switch.
55 was the first year that the main power was distributed off the headlight switch, and the only year the dash light dimmer for the instrument lights was set for 6 volts. If you don't care about dimming dash lights you can use a 56/57 switch or any generic off the shelf switch. They are much less expensive - but your **** won't match.
BUT since you are rewiring and now have a fuse panel, I'm assuming you are converting to 12 volt, and you can use any 12 volt (56+) headlight switch. On the Ford Switches, you can remove the **** and shaft (as you now know) and put one in that is correct for your 55 if that's important to you - be sure to get a **** with the correct shaft length.
Old Apr 20, 2010 | 05:54 PM
tardster's Avatar
tardster
Well I've tried everything Ive read so far and I guess there is no getting it back in and keeping it in there. So any ford headlight switch will work I'm guessing/hoping?
Old Apr 20, 2010 | 06:21 PM
AXracer's Avatar
AXracer
Since you are rewiring, any pull on light switch should work. When I rewired I used a GM style turn to light light switch I got from EZ Wire.
Old Apr 20, 2010 | 07:20 PM
tardster's Avatar
tardster
ok I just went and got a new switch from autozone, now my question is what and where do the wires hook up at. there were no instructions so I dont know what the letters on the switch stand for.
I have an
A
B
P and/or R
D1
D2
H
I
Old Apr 20, 2010 | 08:49 PM
tardster's Avatar
tardster
here is a pic of the new headlight switch, im just having trouble figuring out what is what on here any help is appreciated... thanks
Old Apr 20, 2010 | 08:58 PM
Julies Cool F1
I have an
A
B
P
R
D1
D2
H
I
Tard, you're givin' me a headache!!!!!! But that's ok!
Just move the tabs to the right places the letter hook ups are correct. Your P and R are two seperate tabs P is for parking lights, R is for runniing lights The P is obvious, the R is the silver tab just to the right of the R running light. D1 is for dome lights D2 is for box lights on moving vans.
Name:  P F-100 Headlight Switch 56.jpg
If that doesn't work let me know. It's hard to see the silver tab for the Running lights
Old Apr 21, 2010 | 01:11 AM
tardster's Avatar
tardster
Hey Julie, in the picture it shows the the R and P are the same post. Its the one thats kind of hard to see, oh and im sorry for being a pain...lol I have to call rebel tomorrow to find out why there are 2 dimmer power wires (they really like me calling too)...lol
Old Apr 21, 2010 | 02:21 AM
Julies Cool F1
It's hard to see from the picture, but I thought thee was a silver tab and a gold tab next to the P and the R. The silver tab may stick straight out sideways instead of sticking up. It may be the nature of this switch to have things grouped a little differently and keep the parking lights on while the headlights are on - not sure. If that's the case, then each of those wires would get joined together in one connector and fit on the tab.
Are you sure there's no way to connect to that silver tab - like slide a connector onto it from the side, or between it and the side wall?
Can you take another picture with is SLIGHTLY tilted on its side - like 15 degrees or so so I can see the tabs from both top and side?
Or give me the part number and maybe I can go up to auto zone and look at one.
Thanks
Edit note:
Is this your switch, the Duralast? Because in this picture, there is a tab on this switch that appears to be missing from your new switch. I count 8 tabs on it and only 7 on yours. It seems that the tab in the dead center on yours is missing and that would be the P tab and the R is the one with the brass shunt going to the rheostat - which would make sense. I might be tempted to take it back up to auto zone and ask to see another one or ask them if they have one with 8 tabs on it.
Old Apr 21, 2010 | 04:14 AM
tardster's Avatar
tardster
This is a wells switch part number sw166. I went to their website and looked and as far as I can tell that prong is not there but I will post a link to their website so maybe you can take a look to see if im missing something and thanks again for all the help so far...
WELLS Engine Management Systems - Instruction Sheets
