1994 diesel win problem
Old Apr 20, 2010 | 07:24 AM
Major94's Avatar
Major94
Ok so this truck was advertised as a 95. I recently did a vin decode and it says it was made in april of 1994. But it still has a 7.3 turbo diesel, powerstroke. Is this concidered a 94.5, even though it was in the early half of the year. Also I did a decode on the FTE site and it says it had a 5.0L in it. bu the 7.3 is the stock engine. It didnt go through a gas to diesel conversion.
Please explain
https://www.fleet.ford.com/maintenan...vinResults.asp
Old Apr 20, 2010 | 10:31 AM
cowmilker08's Avatar
cowmilker08
Link wouldn't work.
Just a guess here:
I would say that before you bought it someone did an engine swap.
Also an April 1994 build could easily be a 1994.5, remember in August/September of 1994, the 95's would've hit the lots.
Old Apr 20, 2010 | 11:01 AM
tubss76's Avatar
tubss76
hey major, i too have a 94 f350 with the 7.3 powerstroke etc... and my manufacture date is 5/94 so your truck could of been one of the first off the line with the 7.3.
Old Apr 20, 2010 | 11:31 AM
84-250's Avatar
84-250
you can also look at the flat spot of the block by the oil filter, there is the serial number of that engine. Mine was a 5/94 engine with a serial number of 22k and change
Old Apr 20, 2010 | 12:11 PM
mojoman's Avatar
mojoman
do a search on build sheets...there is a Ford e-mail address...send them your vin ...takes a month maybe and you'll have the original build sheet including all options in your snailmail box...hth
mojo
