Carb swaping
Old Apr 20, 2010 | 04:36 AM
HotrodAerostar's Avatar
HotrodAerostar
Carb swaping
I've got a 1983 f100 with a 4.9 in er. I was considering putting a two barrel on from a ford V8 from around that year. Found the adapter I need for it. Is a swap like that just puting er on n tuning it or is there more complicated things I'm not considering. Also does any one know the cfm of those single barrel carters and the two barrels on the 302s.
Old Apr 20, 2010 | 09:57 AM
f100jim's Avatar
f100jim
Just off the top of my head, you will need to deal with fuel line routing, throttle cable - may need a custom cable, heat for the choke if it has a hot-air choke.
Also, if you have an automatic trans, you will need to deal with the kickdown linkage.
I have heard that the stock Carter YF carb is about 170 cfm.
Old Apr 25, 2010 | 08:44 AM
F-250 restorer's Avatar
F-250 restorer
I believe you will get better mpg with a 4v carb. I would find one used, and rebuild it.
Old Apr 25, 2010 | 12:40 PM
Harte3's Avatar
Harte3
...IF one keeps their foot "out of the pump" with the 4v and holds the Exxon moments to a minimum.
Captain Mel
16
Sep 24, 2013 11:09 AM
|WYG|SS
Feb 7, 2013 10:14 PM
0351mike
1966 - 1977 Early Broncos
Jan 11, 2012 07:45 PM
Reed
32
Jul 2, 2010 10:53 AM
2002BLGT
Nov 12, 2005 02:15 PM
