360 or 390
Old Apr 19, 2010 | 09:32 PM
soundguy567's Avatar
soundguy567
360 or 390
I have a 1976 f100/150 Ranger. I was told it had a 360 but the valve cover actually still has a sticker on it that has engine info for both 360 and 390 and it says engine displacement is 390. Well why question is is there a way to tell the difference from a 360 to 390. If I understand correctly it is the same block with a different crank and rods. any way to tell?
Old Apr 19, 2010 | 10:01 PM
cabloom300's Avatar
cabloom300
Only way is to pull a plug and measure the stroke, if its around 3.5 your have a 360, if its around 3.75 you have a 390.
Old Apr 19, 2010 | 10:05 PM
OrangeJuice's Avatar
OrangeJuice
It is the same block except for the rotating assembly. You can measure the stroke by using a wood dowl in a spark-plug hole. A 360 will measure 3.500'' and a 390 will measuse 3.784''. Hope this helps.
OJ
Old Apr 19, 2010 | 10:08 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Pull a spark plug and bring #1 to TDC. Use a wooden dowel or something that won't scratch the cylinder walls and insert it into the spark plug hole. Make a mark at the threads.
Take #1 to BDC and make another mark.
360 = 3.50 inches
390 = 3.78 or 3 3/4 would suffice on a ruler.
Josh
Old Apr 20, 2010 | 06:47 AM
soundguy567
Thanks I'll try that this weekend
