Howdy Y'all!
Old Apr 19, 2010 | 08:43 PM
fordktpjoe's Avatar
fordktpjoe
Howdy Y'all!
Hi everybody! Name's Joe.
So after 6 months of searching, I finally found it.
1984 F150 4X4 4 speed 300 I6.
bought it from an 80 year old farmer a few miles away from me.
One of the front hubs was broken (**** broke off) so he threw in a set of Mile Marker hubs, which I already put on.
There was also a horrendous exhaust leak from the tube that goes from the EGR plate to the AIR pump, it was rusted in two, so I took that off and stuck a 3/4-14 pipe plug in there. No help.
Turns out the exhaust manifold gasket is GONE. may as well be non existent. ok, it's only a $10 - $15 part, but it's a pretty big job. that'll be next.
While I was taking the carburetor off to make room to get to the pipe fitting, I noticed that the fuel line doesn't go to a mechanical fuel pump on the side of the block...darn, I was hoping to avoid that in-tank pump crap.
Oh Well.
Then I have GOT to eliminate this EEC-IV garbage and go Duraspark...maybe that HEI route, not sure yet.
Was going to post some pictures, but it says I can't post attatchments...sorry.
Old Apr 19, 2010 | 09:25 PM
SatoriEnd's Avatar
SatoriEnd
Welcome Joe!
Your truck sounds darn similar to mine, 'cept my problems all seem to be electrical and fuel system related. Hehe.
Old Apr 20, 2010 | 12:25 PM
fordktpjoe's Avatar
fordktpjoe
OK I got a few questions.
I did a search, but didn't get anything. Maybe I'm not searching for the right phrase or something.
I've read about changing the intake/exhaust manifold bolts out for studs.
Can someone tell me what size studs to get?
Also, I've been reading about needing Chevy "football" washers, but can't really tell from what I've read if they're only needed if one is using an aftermarket intake or exhaust manifold.
Since I am going back with the stock manifolds, and simply replacing the gaskets, do I need these special washers?
Lastly, I REALLY want to ditch this TFI system and computer.
I'd like to go Duraspark II so I could stay all Ford, but have read about the benefits of going with the GM HEI module. Is this actually the better way to go? Seems like sort of a hack job to me.
Joe
Old Apr 20, 2010 | 03:27 PM
LARIAT 85's Avatar
LARIAT 85
You got that right, it IS a "hack job." Stay all Ford!
Seriously though, the GM HEI module is not an improvement over the Motorcraft Duraspark.
Old Apr 20, 2010 | 05:13 PM
Fordzilla80's Avatar
Fordzilla80
When you reply or start a thread,below the box for the title is Message,and then a bunch of options you can click on.If you look at the last row of options,toward the end there is a yellow box with a mountain lookin thing in it.Click on that.It should give you the option to post the url of the image.Post the URL,and click ok or submit.Your picture should show in the thread.If not,post the URL in a reply and one of us can post them for you.
Old Apr 20, 2010 | 06:13 PM
fordktpjoe's Avatar
fordktpjoe
Old Apr 20, 2010 | 06:18 PM
fordktpjoe's Avatar
fordktpjoe
Old Apr 20, 2010 | 06:51 PM
Fordzilla80
She's definitely got that Farm truck look to her.But she looks pretty clean.Good find man.
Old Apr 20, 2010 | 07:37 PM
greyghost85's Avatar
greyghost85
started my duraspark conversion....it will be slow, but hopefully, sure
Old Apr 21, 2010 | 05:52 AM
fordktpjoe's Avatar
fordktpjoe
Nothing on the manifold studs or those Chevy washers?
Old Apr 21, 2010 | 06:28 AM
bashby's Avatar
bashby
dont know about studs/washers but if youre pulling yhe exh manifold anyway you might want to get a newer man from a efi truck, I seem to remember reading that was a good cheap upgraded
Old Apr 21, 2010 | 12:59 PM
greyghost85
i wanna do it, soon as possible
