Need some advice please.
Old Apr 20, 2010 | 10:09 PM
Conanski's Avatar
Conanski
I wouldn't worry too much about the transmission lasting, the AOD was never put behind a 351 either but mine lasted 10 years behind one and is still going. And with overdrive in the gearbox there is absolutely no reason to use anything less than 3.55 gears in the rear axle, if you went with a 289 or 302 that should be 4.10's. That means the motor would be turning a little more rpms at 75mph but that's what has to be done to get performance from a small motor in a heavy vehicle.
Originally Posted by Dmoney88
Being as my truck is already EFI would it be relativly simple to put a 351 EFI in place of the 300?
That depends, it's more than a simple bolt-in because the wiring harness is different and modification have to be made to it, but it is doable because several guys here have completed the task.
As for the motor itself a stock bottom end with GT40 heads, HO cam + 1.7 rockers, and a full exhaust will put out about 300HP and have you burning rubber every time you stomp on it from a dead stop.
Old Apr 20, 2010 | 10:13 PM
Conanski's Avatar
Conanski
Originally Posted by fordman1090
Its been said, there is no replacement for displacement, 50cid is alot more power..
You said it.. my 5.8 was a full 3 seconds faster 0-60 than the current 5.0 in my truck.
and with any v8 swap, you will never see 17mpg again.
Actually my 5.8 got a little over 17mpg cruising at 70mph on relatively flat highways.
Old Apr 21, 2010 | 03:40 AM
Cory281's Avatar
Cory281
The best mpg my 5.0 4x4 with 31's got was 17, mostly it would get 14 with an occasional 15 or 16. In the winter I would get a little worse like 13 from letting the truck warm up in the mornings. Thats with a auto and 3.55's.
With his truck being a little lighter and having smaller tires, I think getting over 15 is do-able.
Old Apr 21, 2010 | 08:50 AM
skyfox10's Avatar
skyfox10
Do you attest that to anything in particular? I think my best mpg was maybe 13.5 highway and think 17 would be awesome.
Old Apr 21, 2010 | 11:17 AM
fordman1090's Avatar
fordman1090
17mpg was the highest i'v ever got with my 300. And that was when it was completely stock with the M5OD and 3.08 and i was driving 55-65 on only highways, day after day last summer.
I cant imagine 17mpg in a 351. But maybe if the conditions are right.
Old Apr 21, 2010 | 11:21 AM
fordman1090
the AOD is a pretty tough transmission. But he doesnt have the AOD. He has the Mazda 5 speed. the Mazda has a hard time staying together behind a 300. And he is building this truck because he wants power and to go fast. Which means that tranny will be abused. From my experience the Mazda wont hold up very long at all and hes gonna need something stronger.
Old Apr 23, 2010 | 12:57 PM
Dmoney88's Avatar
Dmoney88
what transmission should I try looking for? Is the T5 a good transmission for a truck? Also did for make or is there a way to change a motor to and overhead valve system? Also will increasing the stroke of a motor kill the gas milage?
Old Apr 23, 2010 | 02:42 PM
GoinBoarding's Avatar
GoinBoarding
351 Efficiency
I'm sure you'll all call bs, but I rarely get less than 17mpg (empty) highway with my 96' 351w 4x4 3.55 rear end at altitude. Manual lockouts, stock size tires (LT235/75/R15) and not going over about 68-70 mph do it every time. Oh no AIR pump either, and one hallowed cat, not sure if that makes a big difference. If I'm driving from CO to MN, I'll get 18 in NE if I don't stop for 300 or 400 miles. One winter, I drove 47mph (because of the icey roads) all the way across NE , went 300 miles on the rear tank- rediculous I know.
Whats odd is when in CO, I get 17mpg all the time, in MN 16mpg tops. I have a theory, the mass air sensor reads pressure, which is a whopping 19 inches of Hg at 7700 feet (I think 29.7 inches of mercury is at sea level?), so there is about 1/3 the O2 at this altitude. The computer recognizes this and leans it out to try to maintain the A/F ratio of (what is it, like 14.5:1?).
I used to think it was the non ethanol blended fuel we had in CO, but now we have E10, and I'm still getting the same mileage.
Old Apr 23, 2010 | 05:05 PM
Cory281's Avatar
Cory281
Is your truck an auto or manual?
Old Apr 23, 2010 | 08:55 PM
GoinBoarding
I have the E4OD automatic. Oh and a K&N air filter, it came with the truck, I doubt I would have one otherwise.
Old Apr 24, 2010 | 10:51 AM
93MARKIII's Avatar
93MARKIII
and with any v8 swap, you will never see 17mpg again. Regardless of what anyone says. you'll be in the 12-14mpg, maybe 15mpg on the highway, if you easy on it.
i beg to differ......
recent trip to GA from NC, round trip mileage total 900......
bone stock 302, 308 rear end, e4od, '93 flareside, averaged 17 mpg, turning 2k at about 75 mph with 275/60/15 firestones.......
this is in a truck with the original 17 year old spark plug wires/cap/rotor....not sure about the plugs, it runs good so i havent looked at them....
with a proper tune up i see no reason i shouldnt get 18 or better......
this was about 90-95% open high way driving
jes26201
13
Jul 29, 2012 01:16 AM
289FAN
Sep 7, 2011 08:39 PM
FlaBoy
Nov 2, 2004 10:10 PM
FlaBoy
Nov 2, 2004 08:21 PM
broncobuck
1978 - 1996 Big Bronco
Aug 19, 2003 07:00 PM
