Alternator Draining Battery
Old Apr 19, 2010 | 10:17 PM
riggz's Avatar
riggz
Thanks. Will do.
Old Apr 20, 2010 | 09:28 AM
riggz's Avatar
riggz
I think I need to get my meter calibrated. Silly thing reads .2-.4 with the leads not touching anything. But when I touched the leads to the battery posts it did not jump up any.
Old Apr 20, 2010 | 10:07 AM
gearloose1's Avatar
gearloose1
What type of meter do you have?
If you have a clamp type, it is normal... you are suppose to hit reset before you use it to calibrate it.
If you are using a "pass through" lead type ammeter (eg on a VOM), it is suppose to read zero.
I assume these are both digital meters.. not analog.
Old Apr 20, 2010 | 10:31 AM
riggz's Avatar
riggz
Its an Ideal clamp meter. 61-766
IDEAL INDUSTRIES, INC. - 660 Amp Clamp Meters
Old Apr 20, 2010 | 10:36 AM
gearloose1's Avatar
gearloose1
That kind of a meter may not be very accurate at measuring low amperage.
1.5% claimed error on a 600amp range... you are within the error bar.
You can try to use the test leads -- or.. I keep another VOM around for that.
Use a VOM instead. They are $20.
Remarkably, usually more accurate at measuring 50 to 300 milliamp.
Old Apr 20, 2010 | 02:26 PM
69cj's Avatar
69cj
I thought he was trying to read AC to detect a leaking diode!
Old Apr 20, 2010 | 03:01 PM
gearloose1's Avatar
gearloose1
Originally Posted by cheezit
I would suggest you do a parasitic draw test. we are looking for no more then .50ma (imo.50ma is still to high but that is spec) after the modules go in to sleep mode.
Not according to cheezit....
Suggested doing a parasitic draw test....
Old Apr 20, 2010 | 03:05 PM
riggz's Avatar
riggz
Yes, but I was trying to do the poor man's method he described later with checking for AC voltage.
Old Apr 20, 2010 | 03:11 PM
gearloose1's Avatar
gearloose1
Ahhh. That is not clear from this:
Shutech
Apr 21, 2015 09:31 PM
JR2980
Jul 24, 2014 02:25 PM
inalabama
13
Aug 17, 2013 01:55 PM
npccpartsman
Escape & Escape Hybrid
13
Jan 10, 2011 09:08 AM
