Convert '72 F-250 from 2wd to 4wd
Old 04-19-2010, 01:08 PM
cousinit77's Avatar
cousinit77
cousinit77 is offline
I appologize if this has already been dealt with and I am new to the older Fords and this site. I am looking at purchasing a 1972 2wd crew cab. I really want and partially need 4wd. From what I am being told, I would need the transfer case, driveline, rear driveline mod, front axle, linkage.
What else would I need?
Would most everything bolt up or modifications - major or minor?
Any modifications to the original transmission necessary? (Curretn 4 spd manual)
What years are similar that parts could be used from?
I estimate 1,500 - 2,500 in parts, would that be correct?
I have heard from 2 people that the 2wd frames are different from the 4wd frames.
Old 04-20-2010, 12:29 AM
DarrellJ's Avatar
DarrellJ
DarrellJ is offline
Welcome to FTE!
This is a pretty common question, and it came up just a few weeks ago. Here's a link to the discussion, it should probably answer most of your questions...
https://www.ford-trucks.com/forums/9...t-posible.html
Here's a link to an (overpriced, imho) 4x4 crew cab...
http://vancouver.en.craigslist.ca/rd...697608477.html
Good luck with your new truck!
darrell
Old 04-20-2010, 07:49 AM
cousinit77's Avatar
cousinit77
Thank you for the links. It sounds like swapping is much easier, the problem I tend to run across is finding the 4wd crew cabs in which to swap the bodies over on. When I do find a 4x4 crew cab, it is similar to the one you attached, expensive, much outside of where I can go at this time. I found the 2wd in good shape for a cheap price, but I want the 4x4. Thanks for the help it is greatly appreciated.
Old 04-20-2010, 09:50 AM
DarrellJ's Avatar
DarrellJ
DarrellJ is offline
Is the frame different between a crew cab and a single cab? I guess cab mounts would differ, but I mean length, width, bends, etc. Is it as simple as just finding a good single cab 4x4 frame to drop your crewcab body onto?
Bill? JoWilker? Any of the other smart guys?
darrell
Old 04-20-2010, 11:17 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
The crew cab frame is longer...standard single cab long wheelbase is 131 inches, an F250 crew cab is 149". In this case, considering availability (or the lack thereof) of a 4X4 crew cab chassis in his area it might indeed make more sense to convert the existing truck to 4X4. I think it might make more sense than the somewhat dicey option of stretching a single cab 4X4 frame to fit the crew cab.
Stlrrig
Escape & Escape Hybrid
24
08-08-2016 12:49 PM
Tomahawk2506
10-27-2014 07:39 AM
Stacked65
09-11-2014 07:58 PM
1Badxj
06-02-2014 10:33 PM
Nightrain
18
10-20-2010 09:55 PM
Quick Reply: Convert '72 F-250 from 2wd to 4wd
