data plate info
Old Apr 19, 2010 | 12:14 PM
baracade's Avatar
baracade
data plate info
Here is my data plate info, I need it decoded please!
model F100
wb 115
color m
body b81
trans c
axle 17
thanks in advance
Old Apr 19, 2010 | 02:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
model F100
wb 115
color m
body b81
trans c
axle 17
Sequence as listed on the Warranty Plate:
115" Wheelbase.
M = Wimbledon White.
MODEL code F100: F100 2WD, 5,000 lbs. GVWR.
You didn't say what year your truck is. I had to go by the AXLE code to discover you have a 1966.
The colors/patterns are specific to each year, but AXLE code 17 was not used in 1965 for F100's.
B81: B = Medium Blue Crush Vinyl & Medium Blue Cody Pattern Woven Plastic // 81 = 81B Custom Cab.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
17: Ford 9" Rear Axle / 3.25-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
GVW missing. It would be 5,000 lbs. Gross Vehicle Weight Rating.
HP & RPM missing.
DSO missing.
Old Apr 19, 2010 | 02:56 PM
baracade's Avatar
baracade
Smile
Thanks for the info, I did not include the GVW, Hp and DSO because I already knew what they were. Looks like it is all original and it has stayed in the Dallas area. Do you know what time frame Ford built trucks in Dallas?
Old Apr 19, 2010 | 03:59 PM
NumberDummy
1948/72, and prolly much earlier. There is no code for Dallas in the 1973/79 and later catalogs.
Ford built dozens of assembly plants in the US, dozens more in foreign countries, initially to assemble Model T's.
Over 27 miilion T's were sold between 1908 & 1927.
Grey Beard
16
Sep 6, 2021 06:37 AM
hotrod.65
Feb 6, 2013 07:47 PM
bynack23
Aug 6, 2012 07:44 PM
fishman002
Feb 8, 2005 10:21 PM
Mulletwagon
1978 - 1996 Big Bronco
Dec 6, 1999 01:12 AM
