Sponsored by: Auxito
Stupid windshield leak
Old Apr 18, 2010 | 09:37 PM
1poorracer's Avatar
1poorracer
so after a search on here i'm certain the rain this weekend got to the GEM Module.I was wondering how much the part was gonna cost, and if anyone has instructions on how to replace it.Also how much are they charging y'all to reseal the windshield? any help is appreciated
Old Apr 19, 2010 | 09:39 AM
1poorracer's Avatar
1poorracer
well, i'm getting a new GEM Module from the Ford dealership for $155.33 + tax, does that sound about right?
found instructions:
Generic Electronic Module (GEM)
Removal
Disconnect the battery ground cable (14301).
Remove the cover from the instrument panel fuse junction panel.
NOTE: On vehicles equipped with automatic transmissions, move the shift lever to the 1 position to ease removal.
Carefully press the (A) clips and remove the (B) steering column opening cover.
Postion the hood latch release handle aside.
Remove the screws.
Position the hood latch release aside.
Position the parking brake release handle aside.
Remove the screws.
Remove the lower instrument panel steering column cover (044F08).
Remove the six lower instrument panel steering column cover bolts.
Remove the lower instrument panel steering column cover.
Remove the two (A) bulkhead electrical connectors from the (B) instrument panel fuse junction panel.
Remove the two (A) instrument panel fuse junction panel bolts and remove the two (B) interior fuse junction panel nuts.
Disconnect the three (A) GEM/CTM electrical connectors from the (B) GEM/CTM.
Remove the three GEM/CTM screws and the GEM/CTM.
Installation
NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
To install, reverse the removal procedure.
Check for proper operation.
Install the lower instrument panel steering column cover.
Position the lower instrument panel steering column cover.
Install the six bolts.
Install the parking brake release handle.
Position the parking brake release handle.
Install the screws.
Install the hood latch release handle.
Position the hood latch release handle.
Install the screws.
NOTE: On vehicles equipped with automatic transmissions, move the shift lever to the 1 position to ease installation.
Carefully press the (A) clips and install the (B) steering column opening cover.
Old Apr 21, 2010 | 12:06 AM
1poorracer's Avatar
1poorracer
i have replaced it with a new one from Ford, and its throwing the -------- etc still, i havent driven it yet though, just started it, is something still wrong, or do i just need to drive it?
Wagion
Oct 23, 2016 09:05 PM
Memphis_Sean
21
Feb 10, 2015 10:09 AM
LFDavidson
16
Dec 1, 2010 01:06 AM
84-250
General Automotive Discussion
Sep 25, 2008 04:19 PM
fire41fighter
Garage & Workshop
22
Jan 27, 2004 07:34 AM
