Tire size qustion for the 2wd xl
Old 04-18-2010, 03:03 PM
smlford's Avatar
smlford
smlford is offline
Hi-
I'm finally getting rid of the crappy Conti's that came on the truck and looking for some Michelins. The only ones that come in the 225/70-15's
are the good ol' LTX's which I've used for a long time on other trucks.
I recently put a set of LTX M/S 2's on our Denali and it is an improvement in ride quality and it has a very long warranty.
In order to go to the LTX M/S 2's I would have to go up to a 235/75-15.
Is that OK with the stock steel rims or should I just get the stock size?
Thanks.
Old 04-18-2010, 07:26 PM
michigan66's Avatar
michigan66
michigan66 is offline
What is your rear axle ratio? Going to a larger diameter tire may adversely affect the pulling power of the 2.3 engine.
Old 04-18-2010, 11:37 PM
Hank85713's Avatar
Hank85713
Hank85713 is offline
should not be a problem as you are looking at less than 1/4 inch I would say overall. I went from the stock tiny 14 inchers to 235-70 15 when I went to aftermarket wheels. Have a 3:08 gear ratio and still have plenty of power get good milage. Just have to refigure the odometer and speedo. depending on year you might be able to get the computer reset at a dealer. I tried to replace the nylon gear in the trans but it made the error worse, so now I know at 65 iam doing 70 and I add 4 miles /100 when I refuel for milage. No big deal overall. Do a search I forget which company will tell you the dimensions of the tires by size but 235 vs 225 is what 10mm and 75 vs 70 is negligible for size. If I find the site for the dimensions I post it, but any tire shop can tell ya what the differences are from their books.
Old 04-18-2010, 11:48 PM
Hank85713's Avatar
Hank85713
looks like I mised it by 1/4 inch!
29 diam 205R16 235/70R16 255/60R17 255/55R18 LT 235/75R15 205/80R16 255/70R15 255/65R16 235/75R15
28-1/2 diam 225/70R16 LT225/75R15 29X9.50R15LT 8.00R16.5LT
245/70R15 225/75R15
Tire Tech Information - Diameter Comparison of Light Truck Tire Sizes
tire sizing - Search.com
Old 04-19-2010, 05:17 AM
bratman2's Avatar
bratman2
bratman2 is offline
You missed it again as a 225/70/15 is around 27.4" new. Eddie, they should fit the rim without too much trouble. Especially if you have the later model with 7" rims. You are going to lose some on takeoff and your speedometer will read a little slow. Probably only a couple of mph at 60.
mikebrawn1
212
10-04-2021 11:49 PM
allcool
6.7L Power Stroke Diesel
33
12-05-2016 08:56 PM
Jonesy0027
2009 - 2014 F150
17
06-17-2016 06:09 AM
RubenG
01-16-2016 09:16 AM
rhc43
06-09-2010 08:34 AM
Quick Reply: Tire size qustion for the 2wd xl
