starter problems
Old Apr 18, 2010 | 10:31 AM
rip357's Avatar
rip357
starter problems
I recently purchased a 1984 F-250 4wd 4 spd trans. I was informed that the engine had been replaced with a 77 lincoln OR Thunderbird 460. I have been having starter problems, and have replaced it and the solenoid, and ingition switch. The problems (grinding) continue. My question is how do I find out if the correct flywheel has been installed, and which one (with full specs) should be used. Is there a difference in the number of teeth, and angle? There are so many different starters for these engines, I'm a bit confused. Is there a serial number on the engine block, and if so, where? I have head numbers (03ve-a2a) but do not know if that will help. Thanks in advance!
Old Apr 18, 2010 | 09:54 PM
ctubutis's Avatar
ctubutis
Look up the starters & other parts on parts store Web sites (RockAuto Auto Parts is good) and
compare. There is no serial number on the engine. Starters are different for manual vs automatic
transmissions. T-birds & Lincolns didn't come with manual trannies, I'll bet you need the starter
for an automatic....
Old Apr 19, 2010 | 04:26 AM
rip357's Avatar
rip357
thanks i"ll ck that. i"ve had the starter off an on several times. works the first time after that grinds or is very noisy. i would have never considered that. what a deal, thanks.
jrandalls
Mar 26, 2008 08:07 PM
lref1
1997 - 2003 F150
Mar 7, 2007 09:28 PM
Ford Radical
Jan 8, 2005 11:59 PM
fast77
Bronco II
May 13, 2002 09:40 PM
