fuel filter
WIX 33617 - Fuel/Water Separator 1993 Ford F-250 | O'Reilly Auto Parts
yes i just installed one this past weekend and eliminated the metal piece on the bottom. you can get the one with or without the sensor the one in the link is the one with the water in fuel sensor. make sure you fill it up with good diesel or you can fill it with diesel kleen.... jusst make sure its full and let it run a few minutes
nobody really does ha it leaks and was causing me to loose prime in the fuel system.... if you havent got yours off yet you might just want to take a screw driver and a good hammer with you and drive it through and turn it off.... mine was stuck on good and the wrench just slipped around it
cajunbronco
06-16-2002 09:56 PM
