Sponsored by: Real Truck
shift problem
Old Jan 28, 2003 | 06:54 PM
Turfsports1's Avatar
Turfsports1
Question shift problem
1999, F-250 Super Duty 7.3L, 102,000 miles, REGULAR maintenance; pull loads well below max, mostly interstate driving: I have to nearly stand up in my seat, while pushing down the clutch, to down shift after an hour or two on the highway. Often, when I exit the interstate, I must turn the ignition off to get the truck in a lower gear. My regular mechanic says that 4 other owners are having the same problem. Dealer just changes hydraulic oil..no help. Any help?
Old Jan 29, 2003 | 03:32 PM
Quikirk's Avatar
Quikirk
shift problem
Maybe the slave cylinder went bad??
Old Jan 29, 2003 | 04:19 PM
Monsta's Avatar
Monsta
Sit. Stay.
shift problem
Shift fork(s) bent?
Clutch not completely disengaging?
Hey...Where's Mark K.?
Old Jan 29, 2003 | 04:35 PM
FortyFords's Avatar
FortyFords
shift problem
Mark's the auto tranny guy! not to say he wouldn't know about manuals also!
This is a handshaker Monsta !
oops! forgot you know all about them
You either have the slave cylinder gone bad or the center section of your pressure plate or clutch disc
bad also ,there have been reports of the pivot arm
for the throw out bearing bending ,there was a tsb on this for diesels I believe!
Rich
Old Jan 29, 2003 | 08:19 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
shift problem
Here I am!
With my almost non-existant manual transmission knowlege I'd have to say it isn't working correctly.
Someone that knows manuals will have to take over from here. That's about the limit of my manual transmission experience.
Old Jan 29, 2003 | 11:24 PM
Aaron S's Avatar
Aaron S
shift problem
I didn't think you could change just the hydraulic fluid. The replacement slave from Ford comes connected to a new master and is prebled. If it takes that much pressure it sounds like a mechanical problem to me.
Aaron.
sjwelds
Dec 3, 2014 10:42 AM
danielharr79
1983 - 2012 Ranger & B-Series
19
Dec 1, 2005 06:38 PM
broncobasher
Jun 6, 2004 07:52 PM
lydell
24
Nov 11, 2003 04:50 PM
mtstormcars
Feb 13, 2003 12:18 PM
