6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
front receiver hitch
Old Apr 16, 2010 | 07:47 PM
whporwil's Avatar
whporwil
I want to put a front receiver hitch on my 2008 F450 so we can carry two bicycles when were pulling our 5th wheel. Curt and Valley have hitches that are made for trucks that have frame rails measuring 34 inches outside to outside, my truck measures 38.5 inches outside to outside. I assume this has something to do with the wide track front end, or maybe not. Do I have a really special truck or do you other 450's have the same measurment. My truck is not a chassis cab.
Old Apr 16, 2010 | 08:24 PM
BIG BLUE BEAST's Avatar
BIG BLUE BEAST
found this site they got everything.Class III Front Mount Hitch - Ford [31008] - $144.29 : The Hitch Store
Old Apr 16, 2010 | 08:25 PM
senix's Avatar
senix
wonder if this link will help you some:
https://www.fleet.ford.com/truckbbas...0-450_08bb.pdf
Old Apr 18, 2010 | 04:33 PM
StanleyZ's Avatar
StanleyZ
Don't know if it will be a problem for the 450 or not but I ran into a fella in the Georgia mountains who had a front hitch on his 2001 F250 and it was causing an over heating issue under hard hot towing conditions. Just FWIW.
Old Apr 18, 2010 | 08:13 PM
whporwil's Avatar
whporwil
Thanks guy's for your answers. It doesn't look like it's going to be a problem simply because we can't find one made for the wider frame. The parts guys all say this will work but they clearly show 34 inches out side to out side on the frames.
Old Apr 18, 2010 | 09:12 PM
StanleyZ's Avatar
StanleyZ
Try looking under RV. Somebody makes one that is adjustable, I put one on my 5th wheel about 4 years ago. I think it's a valley but not sure but I remember I found it on line. It's a 2 inch receiver tube and the cross piece slides on the brackets which allows you to adjust the width. once adjusted the cross piece is tightened down to the brackets.
Old Apr 18, 2010 | 09:21 PM
whporwil's Avatar
whporwil
I have a Jayco and would have to attach it to the rear landing gear. Question Why a titan and not a trans flow?
Old Apr 19, 2010 | 04:58 AM
mizzitch's Avatar
mizzitch
I would not recommend the front mount receiver for bikes. The bikes move around at bit while driving- this bouncing around is annoying to me...
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Dec 19, 2016 03:26 PM
kkubina
Jul 3, 2015 01:06 PM
jgavac
Jan 20, 2012 08:00 AM
Robert6401
16
Mar 30, 2010 05:50 PM
