Hood gasket question
Old Apr 16, 2010 | 01:13 PM
jazzmaffy's Avatar
jazzmaffy
I notice when my hood is shut there is a good sized space and I was wondering if there is some weather strip that is missing. I looked at the underside of the hood and there are some spaced holes that seem related. It looks like a lot of rain water would blow in that gap when running along. Thanks for any help.
Old Apr 16, 2010 | 01:21 PM
CooGAR's Avatar
CooGAR
There isn't a weatherstrip, but those holes should have rubber bumpers in them. My '65 is missing a few bumpers so I ordered a new set of 6.
Old Apr 16, 2010 | 02:57 PM
BarnieTrk's Avatar
BarnieTrk
Fellas,
IF you're trying to keep your truck as original, realize that the earlier '65s had the 6 oblong hood bumpers and the later '65s were equipped with just 3 round bumpers. Another factor to look at is whether or not you have the original style fenders and radiator support (meaning with the correct number and placement of bumper holes) as it would have had when your truck was originally manufactured.
BarnieTrk
Old Apr 16, 2010 | 03:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's no weatherstrip at the front of the hood, but there is one attached to the cowl where it meets the rear of the hood.
C1TZ16740B .. Weatherstrip-Cowl to Hood / 58" long / Obsolete
Fits: 1961/66 F100/1100 / 1961/66 B500/750 (School Bus) / 1961/69 N/NT/T500/1000 / 1967/69 F800/1000.
DON SANDERSON FORD in Glendale AZ has ONE = 623-842-8762.
AITKEN MOTOR CO. in Aitken MN has ONE = 218-927-2169.
ANTIQUE AUTO SUPPLY in Arlington TX has FOUR = 817-275-2381.
Old Apr 16, 2010 | 06:07 PM
jazzmaffy's Avatar
jazzmaffy
Thank you all for your help.
Old Apr 16, 2010 | 06:18 PM
camperspecial65's Avatar
camperspecial65
In addition to the cowl rubber which is attached with special nails...there are 3 round hood bumpers used on late 65 and 66 model year trucks...they are held onto the fenders(1 per fender at front edge) by a phillips head screw. The one up front is slightly off center screwed onto the upper header panel.
The earlier trucks used 4 side oval bumpers on the fenders which when popped out the oval hole is plainly visible.
- cs65
jminor
May 30, 2014 10:16 PM
BigBlueCat
Jun 26, 2012 01:14 PM
SuperDoodieDutyDude
6.7L Power Stroke Diesel
Nov 1, 2010 10:56 AM
Jag Red 54
40
Feb 16, 2005 09:24 AM
crebic
Paint & Bodywork
Sep 28, 2003 09:22 PM
