sputtering 6.0
sputtering 6.0
Just got my truck back from the shop..sent it in for a sputter at heavy throttle. It was in a few months ago an got a new FICM but this last go round it got a new EGR valve, new cold air charger, and got the Turbo cleaned...ran like a top for a few days but now has the same sputter at heavy throttle. It seems to do it worse when its cold but still does it somewhat when warm. Its not throwing any codes that I know of..any ideas what could be causing the sputtering? And any fix ideas or things to try? Any input helps. Thanks
on
to check the hpop you would need to look at ipr, icp,icpv to start with. did you take it the dealer or aftermarket shop?
most aftermarket shops do not have the ability to diag alot of the simple things like what injector is droping out with out a code. also if they are dont have that ability then they are tossing a part at your truck based only on a code anway.
odds are you have an injector droping out, odds are its not pump related.
on
on the right valve cover is the icp sensor. its got 3 wires and is the only one there. disconnect it and go for a drive and see if it goes away. It will set a code so you will have to clear that when you are done. if the issue goes away suspect icp sensor/connector concern.
may not be it but easy to try.
i will try that and let you know...thanks.. also i remember some time ago i had a programmer on it and got a code for cyl 3 misfire but there was no check engine light and back then it was running like new so i just cleared the code and didnt pay it any mind, is there a way to pull codes without there being a check engine light on?
do you have to have a special scanner to pull those codes? when i pulled the codes without a light last time i did it with a bully dog outlook monitor but dont have it anymore, i was just curious if there is a way i can get codes as it may help me figure out whats going on..once again thanks for all your help!
