Tailgate question 91 F150
Old Apr 16, 2010 | 09:33 AM
DBGrif91's Avatar
DBGrif91
My bed has chrome plates on it that were on it when I bought it. One of them is on the inside of the tailgate. The current screws are 1/2" sheet metal screws, and I'm having trouble with them staying in place. Seems like every time I take it out [it's not my DD] one or more of the 4 screws holding it in place on the bottom side are vibrating loose.
I was wondering if I could upgrade to 3/4 or 1 inch screws w/out interfering with anything? I don't really think there's anything to interfere with at the bottom of the tailgate but I want to be sure before I go ahead with it.
Thanks.
Old Apr 16, 2010 | 03:22 PM
4sabre's Avatar
4sabre
Once a hole has been wallered out or stripped, a larger diameter screw can be put in. I doubt a longer screw will do you any good. It also might help to put a little Loctite on the screw. I would use blue Loctite in case you ever want to remove the screw again.
Old Apr 16, 2010 | 03:27 PM
darthice's Avatar
darthice
hey sabre you from arkansas i thought we were the only ones that used the term wallered LOL anyways he is right a bigger diameter screw will work i have to do this to my trim mounting screw in my cab because the holes expanded (for an 18 year old truck i am not surprised)
Old Apr 16, 2010 | 09:15 PM
DBGrif91's Avatar
DBGrif91
I can look a little closer to be sure, but I don't think any of the holes are loose or stripped. Every time I put the screws back in [they usually only vibrate loose, they don't actually fall out], they tighten down well and aren't stripped. I think part of the problem is that the strip that actually holds the plate in place is keeping the 1/2" screws from getting a good bite on the tailgate sheet metal, which is why I wanted to try a longer screw.
I'll pull the strip off and get a closer look at the holes- if they're not stripped out I'll try a longer screw- if they are then I'll go larger.
Thanks again.
Old Apr 18, 2010 | 06:49 PM
kell104's Avatar
kell104
I had a similar problem, I stepped the screw size up one size and used medium strenth loctite. no problems yet, it has been a couple of years.
Old Apr 18, 2010 | 06:59 PM
inline6/91f150's Avatar
inline6/91f150
Lower tailgate
As to my knowledge their is nothing interfering...unless you have custom applications. I own a 91 f150 and had problems with my latch spring braking. Had to use a BFH to fix it...couldnt reach in there to do anything, and even if I could it would be no use. Luckily the other latch still works. The top of the tail gate has rods for the handle to pull to open it, So be carefull if you mess up there not to block the mechanism.
I'd judt use a bigger, not longer screw tho. Good luck.
Old Apr 18, 2010 | 09:09 PM
Diesel_Brad's Avatar
Diesel_Brad
I just use aluminum rivits. NEVER vibrate loose. If you need to access the tailgate hardware, it is easy enough to drill the rivits out
guessrow
2004 - 2008 F150
23
May 7, 2022 05:01 PM
F 250 6 liter
May 28, 2010 06:50 AM
papadelogan
Dec 14, 2009 10:09 AM
2K3 Mach
1983 - 2012 Ranger & B-Series
May 27, 2005 08:54 AM
rlp
Jun 6, 2003 08:29 AM
