6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Code P2002
Old Apr 16, 2010 | 08:51 AM
hogsanddogs's Avatar
hogsanddogs
Code P2002
Anybody know what this means? Threw this code last night and have 2009 6.4L f250
Old Apr 16, 2010 | 09:18 AM
senix's Avatar
senix
do you have an aftermarket intake on it?
Old Apr 16, 2010 | 09:56 AM
senix's Avatar
senix
From the tech folder:
P2002 REGEN Particulate Trap Efficiency
Below Threshold
This error occurs if an expected pressure drop through the DPF
is lower than the specified value following a regeneration cycle
(based on the concept of normalized pressure differential
but like I said, aftermarket intakes seem to throw the code. So if you have an aftermarket one on there...take it off and see.
Old Apr 16, 2010 | 11:54 AM
Tom's Avatar
Tom
Interesting. Sounds like a "Cracked DPF" code.
Senix, are you sure about aftermarket intakes causing this code? Not sure how one would have anything to do with the other here. Any idea how?
Old Apr 16, 2010 | 12:20 PM
cheezit's Avatar
cheezit
aftermarket intake is the cause. Ive stated this more then once.
the maf is the part of the dpf load calc. they take that and dpfe and that is what causes the code.
so incorrect air flow, dirty maf sensor dirt air filter will cause this.
also it is possible to enter excessive regen based on the same wich will reduce fuel economy and incress speed of oil growth.
Old Apr 16, 2010 | 12:54 PM
senix's Avatar
senix
yuppp, cheezit is the master.
Bluebomber94
Nov 11, 2017 10:20 PM
i eat hybrids
May 20, 2017 10:15 PM
kbf1961
Oct 17, 2015 10:05 PM
88 250
Dec 24, 2010 04:14 PM
KCMAGERS
May 8, 2007 12:36 AM
