How do remove the assembly?
I started pulling bolts from the metal panel behind the headlight (forward of the battery) and nothing moved, so I put them back.
I unwound the two 4mm screws on the top of the actual headlamp that say "not for aiming", and found a third screw holding up the tab in the bottom that has a plastic square 'nut' that rounded when I tried to unscrew it with a 9mm box end.
I can see where the 3 bolts go into the actual corner lense, but can't get to them.
Is the bucket behind the headlamp the assembly?
Is there something hiding behind the plastic trim?
