460 not starting
Old Apr 15, 2010 | 02:40 PM
Red Cobra's Avatar
Red Cobra
460 not starting
my brother was driving my f150 in the yard it has a fuel injected 460 in it... he said it was like the truck ran out of gas (shaking and sputtering) he filled the tank with 20 more liters or so and it did not start back up but i guess they used either on it and said it fired up i have not checked this myself because i have been out of town working i just got back .. i so far have checked that it is priming and there is fuel in the fuel rail now i guess my questions would be what should i check next what should be the fuel pressure be at the little valve and has anyone had this happen to them? it does have a new fuel filter
sorry for the long post and thanx for any help!
Old Apr 15, 2010 | 05:26 PM
subford's Avatar
subford
Not running with pin #6 of the EEC self-test connector grounded and the key on 45 PSI.
Old Apr 16, 2010 | 09:14 AM
Red Cobra's Avatar
Red Cobra
thank you ! this truck is a 1987 the pump in the frame is a high pressure pump then? im guessing because its not starting on either tank so im guessing this could be whats wrong maybe its just to weak? i know its turning on again any help is greatly appreciated
Old Apr 16, 2010 | 09:43 AM
subford's Avatar
subford
If it has spark and fuel pressure in the rail I would check next to see if the injectors are firing. Unplug one of them and plug in a noid light and crank it and see if the noid light flashes.
Old Apr 16, 2010 | 10:23 AM
Red Cobra's Avatar
Red Cobra
a noid light? can i use a simple wire tester to do this test?
Old Apr 16, 2010 | 10:44 AM
subford's Avatar
subford
I do not know what you mean by "a simple wire tester".
If you have a neon test light you could hook it between the two wires of one of the unplugged injectors plugs. That would be about the same as a noid light.
Some auto part stores like O'Reilly will rent a noid light set.
Old Apr 16, 2010 | 03:28 PM
Red Cobra's Avatar
Red Cobra
haha sorry i did mean the test light that you ground then touch it to whatever and the light goes on haha and i looked it up and i will go check the injector wires later today thank you
Old Apr 16, 2010 | 04:56 PM
Diesel_Brad's Avatar
Diesel_Brad
Do you have spark?
Old Apr 16, 2010 | 05:39 PM
Red Cobra's Avatar
Red Cobra
yes thats the first thing i checked
Old Apr 16, 2010 | 06:41 PM
Diesel_Brad
This is an 87 w the carb right? Just pull the fuel line off the carb and see if you are getting fuel. My guess would be the return filter at the carb is returning too much fuel OR your fuel pump relay is bad. You only need 5-8 psi to make the truck run
Old Apr 16, 2010 | 06:53 PM
Red Cobra's Avatar
Red Cobra
its a fuel injected 460 it was swapped in im not sure if the motor before had a carb and i have checked the fuel rail and fuel comes out but not at the 35-40 psi that i was told it should be but i dont have a gauge yet
Old Apr 17, 2010 | 06:32 AM
Diesel_Brad
O an abortion truck. Good luck
Old Apr 17, 2010 | 03:44 PM
Red Cobra's Avatar
Red Cobra
i used a wire tester to check my injector wires and as im turning it over it does not light it up what do i check from here? is there a fuse or relay or?
Old Apr 17, 2010 | 04:17 PM
subford's Avatar
subford
Dose the EEC power relay click when the key is turned on?
In other words do you have power to ground with test light from one of the red wires going to the injector plugs with the key on?
Old Apr 18, 2010 | 04:43 PM
Red Cobra's Avatar
Red Cobra
I guess my injectors are working I took a spare injector and it is poping so I have spark and I have power to the injectors. When I turn the truck on I can hear the relays click and I have fuel in the fuel rail I am lost now could this be a bad computer problem or somehow my timing is now off? What way would I turn the distributor if I wanted to advance it a hair?
and far as it being a abortion truck I don't think it is everything in is where Its supposed to be and there is no hack job wiring and everything worked perfect I thought that 87 and up where all fuel injected ?
