Sponsored by: Real Truck
autometer water temp gauge..
Old Jan 28, 2003 | 03:44 PM
bddo's Avatar
bddo
Question autometer water temp gauge..
I've received my dual gauge pod and gauges and now I am ready to do the install...
I know where to hook the tranny temp gauge in, but not sure where to hook the water temp gauge. I think I read that you use a freeze plug and just replace it with the sending unit for the gauge.
Can anyone tell me where this would be??
Thanks.
Old Jan 28, 2003 | 05:54 PM
FortyFords's Avatar
FortyFords
Using a freeze plug seems like alot of trouble to me !why not tee in right where your idiot gauge is ?
On the 5.4 v8 I used a 1/2 inch plug in the water crossover tube ,look for something like that rather than a freeze plug!
Rich
Old Jan 28, 2003 | 08:45 PM
Quikirk's Avatar
Quikirk
Brian, I did a tech article on this. chk it out. There is a plug on the frt top side of the intake that works out well.
Old Jan 28, 2003 | 10:10 PM
bddo's Avatar
bddo
Kirk,
Great Tech article... Thanks for the help. I'll let you know how it turns out.. I'm starting to wish that I had gotten a 3 gauge pod so I could add the oil temp gauge. Would you recommend it?
Thanks again.
Old Jan 29, 2003 | 03:29 PM
Quikirk's Avatar
Quikirk
Bryan, I think you're covered pretty well with the wtr temp gauge. If your oil temp rises your wtr temp will come up proportionately. Good luck with the install.
Old Jan 29, 2003 | 03:38 PM
FortyFords's Avatar
FortyFords
Maybe you wanted oil pressure instead of oil temp!
Kirk nice job on the tech article!
Rich
Old Jan 29, 2003 | 03:40 PM
bddo's Avatar
bddo
FortyFords,
You are correct...Oil Pressure gauge is what I meant to say earlier...
What gauges do you have?
Thanks.
Old Jan 29, 2003 | 05:08 PM
FortyFords's Avatar
FortyFords
I have oil press/wt temp/trans temp all autometer
mounted in carbon fiber dash pod .
Welcome to FTE!
Rich
