Rear Bumper
Old Apr 15, 2010 | 07:03 AM
Justin's Green Truck's Avatar
Rear Bumper
Hello. I have a 1977 F150 Custom 4x4 Styleside. Im getting rid of my old rear step bumper and putting on the factory style non-step bumper. My catalog shows the bumper brackets to be different for these two bumpers. Does anyone know where i could find the correct ones for my new bumper?
Old Apr 15, 2010 | 07:36 AM
I found some for sale but they are listed as being for 72 and earlier trucks. They look very similar however to the illustration in my catalog for the 73-79. Does anyone know if they're different? I figure my luck, they are.
Old Apr 15, 2010 | 10:12 AM
75F350's Avatar
75F350
I believe those brackets will work. I used Bronco brackets. Seemed a little more common.
Old Apr 15, 2010 | 12:01 PM
Well, i was just informed that pre 73 brackets would not work so im kinda afraid to buy them. So you used Bronco ones huh? Were there any modifications that you had to do to make them work? Also, where did you find them? The picture you've shown is precisely how i want mine to look so thanks alot for the help!
Old Apr 15, 2010 | 05:58 PM
75F350's Avatar
75F350
I dont know why they would be all that different, I mean the same basic hardware is there. The biggest difference would be where the bolt holes for the frame line up on the bumper and the frame. There could be an issue in the area where the bracket clears the undersside of the bed, and the bumper might sit too low, but this is easy to address.
Since the truck you are looking at is a 75 4x4, it has a narrower frame than the Bronco, F100, F150, 2wd F250 / 350 or 78/9 Fseries.
What I did was added a small piece of material to the bracket to make the bracket move in yet still retain the factory bumper hardware. Now it can adjust enough to meet the frame of the narrow truck, and bolt like a factory application.
Perhaps you are looking for a 100% factory correct look, but you would be hard pressed to even notice that my brackets are for a Bronco, and not for this truck.
I dont think your problem is all that difficult to remedy.
You close to So Cal? Bring it over to The Shop and I will help you
Old Apr 15, 2010 | 10:47 PM
Nah, im a loooong way from so cal. Im in Georgia.
It does'nt really have to be 100% correct to suit me, I just though that surely I could find the right brackets. But from what I understand, most of these trucks came with the step bumper so they're kinda hard to find. I would gladly use the bronco ones though if I knew where to find some.
Old Apr 16, 2010 | 11:37 AM
ChaseTruck754's Avatar
ChaseTruck754
yes they are rare on these trucks and they also aren't super common on the broncos - but they are easier to find on broncos than our dentsides.
75F350 just happened to be so lucky as to having a friend who was parting out a bronco that happened to have that bumper...
After seeing it on the truck I kind of regret letting it go. These things look GOOOOD
Old Apr 16, 2010 | 07:00 PM
alconk's Avatar
alconk
The outer brackets from the Bronco will work perfectly but the inners you will have to weld on extensions to bolt on to the frame. I did the same thing. The inners are too short to reach the truck frame so I used a plasma to to square off the bracket then took stainless stock and welded them together. Worked perfectly..
