6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Tweeters pre-wired?
Old Apr 14, 2010 | 09:23 PM
AZ Elk Hunter's Avatar
AZ Elk Hunter
Tweeters pre-wired?
I have an 09 Lariat and forgot to order the upgraded sound system so I am building it myself. I recently purchased the sail panels with the built in tweeters and was wondering if the wiring will be in the doors for them? I popped the old sail panel off and didn't see the harness? Worst case, I will t-tap the front speaker wires but I am hoping I dont have to.
Thanks for any help.
Old Apr 15, 2010 | 12:24 PM
rjlabonte's Avatar
rjlabonte
Go to the Dealer you bought the truck from and ask them for a wiring schematic of your current and upgraded sound system. They should have no problem making copies from their manuals.
I have done this before for the electric windows in one of my vehicles.
Old Apr 15, 2010 | 01:16 PM
thw420's Avatar
thw420
I did the same thing with my XLT. Sounds much better - really raises the soundstage. I got mine off ebay and they came with the extra wiring harness/splitter. All the harness does is split the original wiring (from radio to door speaker) wiring into 4 wires instead of 2. You could save some money on the harness just tapping into the current wiring. But if you don't want to do that, the harness fits perfectly, and mounts securely to do doorframe. I believe there is a miniature crossover mounted in the tweeter suroundings - to block the lower frequencies from going to the tweeter. Sounds good now
Old Apr 15, 2010 | 02:29 PM
jeff7825's Avatar
jeff7825
So does this mean it is pre-wired?
Old May 28, 2010 | 09:33 AM
F150Lasso's Avatar
F150Lasso
The harness that you got from ebay, was it a factory part? did it just plug into the existing harness? I already have the tweeters and was thinking of putting them in the doors unless I could just plug them in behind the dash then I could just buy the pillars for tweeters. any pics?
Thanks
Rainmaker1
Jan 14, 2017 02:37 PM
mikereidjr
WTB - Parts & other
Nov 30, 2016 02:24 PM
bigdaddyII
2009 - 2014 F150
Apr 18, 2016 01:57 PM
ArrizX
2009 - 2014 F150
30
Aug 11, 2015 05:03 PM
kornfanjoe
Apr 16, 2014 10:18 PM
