1985 Ford f250 ......HELP
Old Apr 14, 2010 | 06:51 PM
travcpr1's Avatar
travcpr1
We bought a 85 F250, as we started driving it, it would die but starts right back up. Sometimes it only dose it once a day other days it can 5-6 times. Today one top of that it has started back firing, black smoke with alittle jerking motion...any ideas
Old Apr 14, 2010 | 08:38 PM
FordNFishinLover's Avatar
FordNFishinLover
Try adjusting the carb air/fuel mixture.
Black smoke usually means your running rich and burning extra fuel.
Old Apr 14, 2010 | 08:42 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Welcome to the Site!
We're going to need more info to be able to help you. What engine do you have? Is it all stock or have mods done to it? let's start there...
Old Apr 14, 2010 | 09:18 PM
travcpr1's Avatar
travcpr1
We have a 460 big block, all stock
Old Apr 14, 2010 | 10:31 PM
Bern_F150_4x4
Okay, '85 460, that means we can rule out the pesky TFI module... Is the stalling part of a sloppy idle issue or will it just cut out for no reason? Will it stall when it is cold or only after it has been run long enough to fully warm up? Backfiring and black smoke sound like a carburetor issue. Check the choke to ensure it is fully open when the engine has warmed up. There is a possibility that you have a failed power valve in the carb. This is difficult to diagnose and is usually repaired as part of a complete carb rebuild.
Old Apr 15, 2010 | 09:43 AM
travcpr1's Avatar
travcpr1
No it dies for no reason, just sitting at an idle or doing 70 on the freeway
Old Apr 15, 2010 | 12:53 PM
Grubbworm's Avatar
Grubbworm
I've heard of that problem before. My dad had an issue like that with his Grand Marquis, sometimes it would just die, sometimes it would die when you floored the gas and run again when you let off. Ford said it was the module and replaced it. That seemed to fix the problem, good thing it was under warranty. I say check the module. Also, you might see if it is setting any trouble codes.
Old Apr 15, 2010 | 02:19 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
1985 - Codes ...
NOT!
-Enjoy
fh : )_~
Bern_F150_4x4
Do you have dual tanks or electric fuel pump(s)? If it is ignition related, it could be the DSII module, the pickup in the distributer or the ignition coil. Too bad it doesn't stay dead, kinda hard to troubleshoot intermittent problems. I would suspect the DSII module first. Maybe hit a junkyard for a few "test parts"? Carb'd 460's don't have a computer so no codes to pull...
Old Apr 15, 2010 | 08:59 PM
travcpr1's Avatar
travcpr1
[quote=FordNFishinLover;8771650]Try adjusting the carb air/fuel mixture.
which way do we turn the screws to lean it up?? Counter clock???
Old Apr 15, 2010 | 09:00 PM
travcpr1's Avatar
travcpr1
[quote=Bern_F150_4x4;8774388]Do you have dual tanks or electric fuel pump(s)? If it is ignition related, it could be the DSII module, the pickup in the distributer or the ignition coil. Too bad it doesn't stay dead, kinda hard to troubleshoot intermittent problems. I would suspect the DSII module first. Maybe hit a junkyard for a few "test parts"? Carb'd 460's don't have a computer so no codes to pull..
It has dual tanks and manul pump
Old Apr 15, 2010 | 09:02 PM
FordNFishinLover
Turn both screws all the way tight. This will make it lean.
Now back them off 1 1/2 turns. This is standard.
Now try starting truck and see how it runs, and you can fine tune it. Slowly turn one 1/8-1/4 of a turn until you get it where you need it. Also make sure that you turn each equal amounts.
Old Apr 15, 2010 | 09:20 PM
travcpr1's Avatar
travcpr1
Will this help the dieing part of the issue??
Old Apr 15, 2010 | 09:25 PM
FordNFishinLover
If your not getting the correct amount of air or fuel your trucks not going to run right and it can die.
So in a nut shell, yes this could be the cause of your truck dieing.
Old Apr 15, 2010 | 09:28 PM
travcpr1's Avatar
travcpr1
[quote=FordNFishinLover;8776093]If your not getting the correct amount of air or fuel your trucks not going to run right and it can die.
Okay we will try it right now, and let u know.
Thanks
