Grant steering wheel horn problem?
Old Apr 14, 2010 | 06:31 PM
Sayer Lane's Avatar
Sayer Lane
Ok guys I got one for you. I just turned 16 got my grant steering wheel for the old girl and the horn won't blow. To tell the truth I could care less if it works but my mama keeps tellin me to fix it. To my knowledge i installed everything correctly and its like the horn when u push it, its not completing the circuit. It is painted black
Old Apr 14, 2010 | 06:58 PM
75F350's Avatar
75F350
You painted it black? Provided that you wired the thing correctly and the horn is functional, the paint does not conduct electricity, and you cant get a good ground. Without the ground, the horn wont work.
Old Apr 14, 2010 | 07:01 PM
Sayer Lane's Avatar
Sayer Lane
I didnt paint it black i bought it from summit its the black series not the chrome series
Old Apr 14, 2010 | 07:11 PM
75F350's Avatar
75F350
Ok, then you have to make sure that the wire from the column that goes through the adapter is functional. You can test this by removing the horn button, and disconnecting this wire and touching it to a known good ground. Usually the center shaft is adequate.
If this checks out ok, then you have a problem with the horn pad assembly. Check the instructions and verify that you have the spring and wire connected to the correct terminal. I believe there are two.
The three bolts in the middle should create the ground, also make sire that the fiber plate is not upside down. It can fit both ways I think, and the horn button wil still snap on there.
Does the horn button feel right when you push it?
Maybe pop the horn button off and take a pic. Usually this can be identified fairly easily.
BDawg171's Avatar
BDawg171
Mine had a foil ring sticker that I had to put on for the reason stated above. Was there a foil sticker with your wheel or install kit? Im 80% sure it came with the install kit!
Old Apr 14, 2010 | 07:18 PM
Sayer Lane's Avatar
Sayer Lane
No sticker. but i looked it up and it was the right install kit for the black steering wheel
Old Apr 14, 2010 | 11:12 PM
jsutton's Avatar
jsutton
I don't have the black one, but I have a grant wheel. I had to scratch some of the paint off under the horn button so that it would get a good ground.
As stated above make sure the metal side of the disk that the horn button attaches too is down.
Actually the horn should have been blowing like crazy while you were putting the horn button on, because you have to push down and twist to get it to lock on the disk. At least thats the way mine is.
Whenever I have taken my steering wheel off I have to disconnect the horn under the hood to keep it from blowing when attaching and taking off the button from the center of the steering wheel.
Old Mar 9, 2014 | 07:31 PM
95F350XL's Avatar
95F350XL
I just installed a black grant wheel in my 91 F350 and have the same issue. I even installed the metal disk and it didnt do anything. I took 3 1/4 thin washers and put them to hold the contact disk to the wheel. The stupid contact disk keeps the bolts from making the ground. The washers connected the bolts to the rest of the disk. Then the horn blew like crazy when I tried to put cap on. Grant instructions are garbage.
Old Mar 9, 2014 | 08:14 PM
Jklnhyd's Avatar
Jklnhyd
The instructions say, to disconnect the negative ground at the battery, for those that actually read them...
Check your fuse, you mighta blown it while connecting it with the battery connected
Isnt the spring to the center shaft the ground? The 3 shoulder bolts appear to be purposely isolated from the disk.
Old Mar 9, 2014 | 09:17 PM
FEMAN78's Avatar
FEMAN78
try checking the rag joint where the steering shaft connects to the gearbox, this is where the steering grounds to the frame thru the gearbox.
Old Mar 9, 2014 | 09:29 PM
Jklnhyd's Avatar
Jklnhyd
FMC will be along shortly and straighten us all out, lol.
robotunderpants
15
Sep 29, 2016 10:22 PM
BigBore44
Nov 13, 2015 01:42 PM
JH1975
Aug 13, 2015 10:18 AM
Green72F250
Jun 26, 2014 02:40 PM
nothercrash
Aug 12, 2011 11:08 PM
