GAWR?
Old Apr 14, 2010 | 06:49 AM
MadFrank81's Avatar
MadFrank81
GAWR?
Hey folks, any ideas what my GAWR's would be for this beast? I noticed there's an extra set of leaf springs on the rear axle that only take load if the rear sinks low enough and the seller said the front end was "converted to a BUD front end" -which means nothing to me, how about you guys?
Just wondering what kind of load it can handle. Frame is a F250 if that helps any.
Old Apr 14, 2010 | 11:13 AM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
......Not much. If it's the stock "Highboy" axles, 5300 rear - 3500 front. If a Dana 70 rear axle has been swapped in, those can handle about 7500.
Old Apr 14, 2010 | 01:47 PM
monsterbaby's Avatar
monsterbaby
you might also want to check your tires that sometimes is even less then your axles. It is printed on the sidewall max load single and dual.
Old Apr 14, 2010 | 04:19 PM
MadFrank81's Avatar
MadFrank81
Yeah, didn't occur to me until after I'd left for work that you guys can't tell me much without knowing the axle types. Will have to crawl under there this weekend to see.
Old Apr 14, 2010 | 05:25 PM
HillbillyDeluxe81
Also, the ratings I gave you were the Ford maximum. The manufacturer rated them a few pounds heavier. This is also assuming you have an open knuckle Dana 44 front. A closed knuckle may be rated slightly less.
Old Apr 14, 2010 | 05:31 PM
Richards73's Avatar
Richards73
how do u no if u have a open knuckle or closed knuckle? and what exacly does that mean? dont no much about it and not tryin to take over the thread just wondering
Old Apr 14, 2010 | 05:39 PM
HillbillyDeluxe81
Open knuckle = you can see the universal joints in the steering knuckle
Closed knuckle = you can't.
Old Apr 15, 2010 | 02:17 AM
Richards73's Avatar
Richards73
o ok thats simple thanks
MadFrank81
Aug 2, 2010 01:46 PM
MadFrank81
Jun 5, 2010 08:46 PM
MadFrank81
29
Apr 13, 2010 07:05 PM
sportinh2o
Feb 3, 2009 10:56 PM
fordTruckFan
Jan 14, 2002 09:32 AM
