np203 to np205 conversion
Old Apr 13, 2010 | 06:26 PM
FordmanShane's Avatar
FordmanShane
okay i have a bone stock divorced NP203 Tcase on my truck, i just recently bought a Driver side drop Np205 now im not sure if i can and cant do.
would i be about to use one of these rods
<a href="http://s83.photobucket.com/albums/j291/exittrippkat/?action=view&current=SAM_0566.jpg" target="_blank"><img src="http://i83.photobucket.com/albums/j291/exittrippkat/SAM_0566.jpg" border="0" alt="Photobucket"></a>
could i use the stock stick
<a href="http://s83.photobucket.com/albums/j291/exittrippkat/?action=view&current=SAM_0567.jpg" target="_blank"><img src="http://i83.photobucket.com/albums/j291/exittrippkat/SAM_0567.jpg" border="0" alt="Photobucket"></a>
what would i need, would i need a new rear drive line?
<a href="http://s83.photobucket.com/albums/j291/exittrippkat/?action=view&current=DSCF0014.jpg" target="_blank"><img src="http://i83.photobucket.com/albums/j291/exittrippkat/DSCF0014.jpg" border="0" alt="Photobucket"></a>
<a href="http://s83.photobucket.com/albums/j291/exittrippkat/?action=view&current=SAM_0565.jpg" target="_blank"><img src="http://i83.photobucket.com/albums/j291/exittrippkat/SAM_0565.jpg" border="0" alt="Photobucket"></a>
let me know what you know from experience...
Old Apr 13, 2010 | 06:40 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
Well, you gonna need to get a 205 shifter.......and modify the driveshafts.
Old Apr 13, 2010 | 06:48 PM
75F350's Avatar
75F350
When I swapped mine, I changed the driveshafts due to the difference in length of the 203 case. The 205 is smaller, and the yokes were different.
Once you figure out the bolts for the brackets and the crossmember, you will have to change up the shifter a little bit. Your current shifter has two levers attached to a mechanism that selects the range box and output section.
Whatever, you need to remove these and modify one rod to activate the plate that connects to the two shift rails on the 205.
If this shifter is a conversion shifter from a part time conversion, then you may have to undo the locking mechanism and create a simple pivot.
After all the factory 205 shift lever is nothing more than a simple lever with a pivot.
This is really a very simple procedure.
Old Apr 13, 2010 | 06:52 PM
75F350's Avatar
75F350
I dont think his automatic trans has any provision to mount the large pivot bolt.
I'm pretty sure that this tailshaft only has the threaded boss for the 203 shifter.
Dang, I cant remember if they have both or not.
If it does, then a stock shift lever is all it requires.
FWIW: this is a great time to twin stick the thing.
Old Apr 13, 2010 | 07:03 PM
HillbillyDeluxe81
Yeah....I've never fooled with the divorced setup.....so I had no idea how it mounted. I just knew his 203 shifter wasn't exactly gonna bolt up.
Keep in mind this is the same guy who said: "a stock 6 inch lift on a f250 highboys right...highboys production ended in 76 right..everything down is lowboy"
......I thought it best to keep things simple.
Old Apr 13, 2010 | 07:34 PM
FordmanShane
my sources proofed wrong nuff said
keep in mind there's no need for people like you...
Old Apr 13, 2010 | 08:04 PM
HillbillyDeluxe81
Well.....whether you were right or wrong is irrelevant. However, another member said you were wrong.....and you responded by "misspelling" his name and throwing a fit. That sort of thing is not tollerated well around here.
Old Apr 13, 2010 | 08:22 PM
75F350's Avatar
75F350
Poor guy has taken a beating over that, its been going on all day. Ive been bored, and having to do some programming work using my puter so Ive been hangin around and keeping an open window, and have seen some nonsense today.
Most are in a bashing type attitude, and not quite having the manners that we have been known for on this site.
No biggie, but I do have a serious question for shane:
Interested in selling the range box out of that 203 set up?
Are you closer to San Joaquin or Sacramento? I think I remember Sacramento.
Either way, do you need some parts for this swap? maybe we can work something out.
Old Apr 13, 2010 | 09:01 PM
FordmanShane
i concur, what did you have in mind..
Old Apr 13, 2010 | 09:05 PM
FordmanShane
is it lonely there on your pedestal?
Old Apr 13, 2010 | 09:11 PM
75F350's Avatar
75F350
Buying your old 203 range box. I may have some parts that you need.
Matter of fact, I have everything that you need. Complete transfer cases, bushings, shifters, twin stick upgrades, skid plate for transfer case.
All of it I have, but you may already have what you need.
You might be a little too far away to ship heavy stuff like this, but Im interested in just the "range box" not the entire case.
The range box is just the little section that bolts to the front of the case itself.
Old Apr 13, 2010 | 09:17 PM
FordmanShane
what's your 20, the only thing i have is the 205 Tcase
Old Apr 13, 2010 | 09:37 PM
75F350's Avatar
75F350
The Shop is in Pomona, Ca.
(91766)
Old Apr 13, 2010 | 09:59 PM
FordmanShane
welp im here in the central valley (95348)
let me know what you want to do..
Old Apr 13, 2010 | 10:13 PM
75F350's Avatar
75F350
Merced is about 300 miles away. Thats a bunch of distance. I suppose shipping the range box itself is not that bad.
Pm me, and we can discuss price, as well as anything you might need.
