Sponsored by: Kumho
Spring rate calculations.....
Old Apr 13, 2010 | 04:18 PM
HRDROKN's Avatar
HRDROKN
Hey Guys....
I built a four link front with coilovers under my 69 Crew Cab and being that I was unable to weigh the truck corners for proper spring rate, I just took a guess. Well the guess turns out to be too stiff.
I'm using a 14" 500 lb. spring over a 18" 750 lb. spring and when I loaded the suspension, they only compressed a total of 3.250". The top spring compressed 2.00" and the bottom 1.250".... so from that information can the correct spring rates be determined? Looking for about a total of 8.00" of compression at ride height.... so another 5.00" of drop.
I know that there are some engineer types on this forum.... hopefully someone can be of some help on this!
Thanks!
Old Apr 13, 2010 | 05:21 PM
gearloose1's Avatar
gearloose1
You need to use a calculator like this:
Compression Spring Constant (k) Calculator - Engineers Edge
Old Apr 13, 2010 | 05:30 PM
75F350's Avatar
75F350
You have some variables that make this a difficult question to answer.
One you have addressed, and this is the force applied to the coil itself.
Next is the angle in which the spring has to operate. Vertical mounting means that the spring is the most efficient, and any working angle at all will kill some deflection.
The same is true for mounting of the spring, and where it is mounted relative to the link pivot(S).
Link suspensions can work like cantilevers, and this will have an affect on the overall rate of the spring as well.
Old Apr 14, 2010 | 10:15 AM
HRDROKN's Avatar
HRDROKN
Compression Spring Constant (k) Calculator -* Engineers Edge
Thanks for that link.... going to play with the numbers and see what comes of it.
Old Apr 14, 2010 | 10:21 AM
HRDROKN's Avatar
HRDROKN
Yes... I have only a few degrees of angle (inboard at the top), otherwise mounts are at the axle centerline. I think that my mounting would only have minor effects on the overall rate? The initial calculator that I used took these things into account.
Mcrafty1
Sep 17, 2013 04:20 PM
harrington
Jan 5, 2013 04:05 PM
Ford_Forgotton
Oct 15, 2009 10:57 PM
Madmaxz
Jun 20, 2008 06:12 PM
muscletruck7379
May 15, 2004 11:51 PM
