Axle interchange question
Old Apr 13, 2010 | 01:10 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I am trying to find out physical interchange on the Ford 10.25" axle. I have a 1986 F350 DRW pickup with a bad bearing tube on the left side. Other than the obvious difference when RWAL was introduced, what years will fit. Second question, other than the actuall differential internals what is the difference if any between a traction-loc 10.25 and an open 10.25? I already know the SRW housing is shorter than the DRW, I have one from a 90 F250. Thanks,
Old Apr 14, 2010 | 11:26 AM
dicksshortwide66's Avatar
dicksshortwide66
Measure the leaf perches, it should fit. I doubt they changed much, maybe the length of the driveshaft yoke, but, I doubt it. That old truck won't worry about the abs. Rich
Old Apr 14, 2010 | 08:15 PM
85lebaront2
The spring perches on the SRW and DRW are the same, the overall length is different. I may have a line on a 92-96/7 F350 DRW rear.
Bigpipes 35
Oct 19, 2023 07:15 AM
old blue beast
May 7, 2015 08:27 PM
lil ford mec
Feb 18, 2014 01:40 AM
brokeasajoke
Sep 28, 2013 01:12 PM
number_7
Aug 27, 2010 09:56 PM
