Need advice. Replacing coolant sys. parts
Old Apr 13, 2010 | 12:51 PM
bluescrew's Avatar
bluescrew
Well guys my job for today is to figure out which parts to replace for the biggest job i have done yet on my rig.
So far on my list is:
-90 deg. hose fitting off water pump
-o ring behind it
-thermostat
-bottom rad hose
-serpentine belt
while i am in there is it worth replacing:
-water pump
Old Apr 13, 2010 | 01:19 PM
Fat Diesel's Avatar
Fat Diesel
I replaced the coolant expansion tank with a nice brand new WHITE one instead of the ten year old yellow nasty looking one and put a new hose that goes out the bottom. Ten years is long enough for me and the new white tank looks great. You can actually see the color of the coolant through it! Heater hoses are now 10 years old. I am not saying that's the lifespan, just saying it could use a preventative maint. change-out.
Old Apr 13, 2010 | 01:37 PM
bluescrew's Avatar
bluescrew
tank would be nice but not right now
yep, im replacing the bottom hose, top one looks alright so ill keep it
i was thinking along the lines of belt tensioner/pullys, stuff with bearings attached to the belt.. moving parts?
Old Apr 13, 2010 | 02:12 PM
Fat Diesel's Avatar
Fat Diesel
How many miles on it? Tensioner was bad at 150k on mine. There's the upper hose, the lower hose, and the vertical hose that is under and behind the white tank. That's the one I'm talking about.
Old Apr 13, 2010 | 03:08 PM
bluescrew's Avatar
bluescrew
just used google, 316 000 kilometers = 196 353.297 miles.. ill put that in my sig!
Old Apr 13, 2010 | 04:15 PM
Waynenap's Avatar
Waynenap
I've had my truck since Jan. 1, 2010 and I don't know what has been done to it. It has 157,000 miles on it now.
I'am replacing the:
Water pump, riff raff
thermostat, riff raff
housing, riff raff
upper and lower hoses, napa
coolant temp. sensor, napa
tensioner pulley, napa
idler pulley, napa
serpentine belt, ford
ford premium gold coolant, 4 gal.
and have done a complete distilled water flush (27 gal.).
I don't know your situation, but it made no sense to me not to do it under the circumstances. In my 50 years of driving, I have been left stranded in the middle of nowhere a lot more than once because of the failure of some of the parts listed above.
No disrespect or carcasm intended, here!
Wayne
Old Apr 13, 2010 | 11:08 PM
bluescrew's Avatar
bluescrew
thats the response i was looking for!! appreciated!
Old Apr 14, 2010 | 06:08 AM
Waynenap's Avatar
Waynenap
Except for the bite in your wallet, you'll never regret.
Wayne
