95 f150 4wd does not work
Old Jan 28, 2003 | 10:00 AM
davewatson's Avatar
davewatson
Angry 95 f150 4wd does not work
I bought a 95 f150 4wd. when i bought it the 4wd worked in 4hi but not in 4lo.(it has electric push button switch) After 4 weeks all the 4wd quit working. I changed the switch on the dash and I changed the motor on the transfer case. did not fix it! The switch on the dash has power to 3 wires on one side of the switch and the last one on the same side has power when the headlights are on.There is a speed sensor on the back of the transfer case. All the fuses are good,I checked 3 times. What am I missing? What other sensors or relays are there? thanks
Old Jan 28, 2003 | 05:19 PM
MustangGT221's Avatar
MustangGT221
Does the light on the dash come on and you just have no 4wd? Did you try to select 4wd and see if the drivetrain is turning (maybe hte light bulb is out)? You know you have to be stopped in park with your foot on the brake to get into 4L right?
Old Jan 28, 2003 | 06:10 PM
davewatson's Avatar
davewatson
the light does not light up and the 4wd does not work either. I was told the light would light up when the motor kicked in the 4wd, so it must be a bab motor, so I replaced the motor, no luck.
