Headlight switch problem.
Old Apr 13, 2010 | 10:48 AM
Lost_Arkitekt's Avatar
Lost_Arkitekt
Question Headlight switch problem.
Okay...so I've been gone for quite some time. I have a 1963 F100 with a 74 302 and a three speed manual.
Last fall, I rewired the entire truck. The issues came about from welding on the car with the distributor plugged in. It fried the Unilite E-Spark module. So, I bought a new one. Truck still didn't run. I use this as a work truck, so I park on the street in Chicago...COLD WINTER. I didn't work on the truck all winter. Finally, found out the module was DOA. Truck runs like a top.
Anyway, while rewiring the entire harness from EZ Wiring, I had some issues, but everyone was really helpful (Thank you all), and now, the thing is almost perfect. However, when I put the headlight switch in the parking light mode (first click), I get parking lights in front AND headlights, but I don't get any tail lights. When in headlight mode (2nd click), I get headlights and tail lights, but I don't get front running lights. I bought the headlight switch from MAC Auto. Everytyhing else (instruments, turn signals, etc.) work fine.
Any help would be great. Ideally, I'd want running lights in the parking light mode AND headlight mode...and headlights in headlight mode only.
Thanks in advance.
Cheers,
Paul
Old Apr 13, 2010 | 10:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The parking lights do not stay on when the headlamps are turned on, they go off.
This is the way things worked back then.
The headlamps are not supposed to come on when only the parking lights are turned on.
The taillamps are supposed to come on (light up) with the parking lights and the headlamps.
Old Apr 13, 2010 | 11:20 AM
Lost_Arkitekt
Now what...
Okay, so I guess I won't get parking lights on with the headlights if I "fix" this issue. However, what do I do to actually fix it? It is a typical headlight switch from MAC Auto Parts.
I think the pins read as such:
R
I
D
P
H
B1
B2
Right now, I have tail lights hooked up to R, instruments to I, dome return to D, Parking lights to P, Headlight wire (to foot switch) on H and B1 and B2 is a split wire coming from headlight breaker circuit on fuse panel.
What do you think I did incorrectly?
Thanks,
Paul
Old Apr 13, 2010 | 11:44 AM
NumberDummy
Dave (garbz2) said in a post t'other day that the 1961/64 headlamp switch will not work with the Painless wiring harness.
Whether this is also true for the EZ wiring harness, I dunno...but I would think Dave does.
Old Apr 13, 2010 | 11:50 AM
Lost_Arkitekt
So, which switch do I buy?
Paul
05victorylly
16
Aug 16, 2013 05:37 PM
80f250ranger
Apr 22, 2013 06:08 PM
Twilight Fenrir
16
Sep 22, 2012 01:13 PM
loyal
Electrical Systems/Wiring
Jun 14, 2009 03:46 AM
