Sponsored by: Auxito
noisy rear end
Old Apr 13, 2010 | 02:37 AM
dailyrider99's Avatar
dailyrider99
noisy rear end
I have a 2000 F150 7700, & have been advised rear cluster needs replacement. Ford dealer wont provide part #'s to shop around. could you help me? What all parts need replacement?
Thank you from Montana,
Gerry.
Old Apr 13, 2010 | 04:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
I can give you the Ford part numbers, and an FTE Ford dealer parts dept sponsor (in WA) you can buy the parts from at a discount, but first I need to know four things.
What is 7700, the GVW?
What is the rear axle ratio?
Does the rear axle have Limited Slip...or not?
Don't know? Post the AXLE code found on the Certification Label.
What parts are you refering to as the cluster? There is no such thing in a rear axle.
Are you asking for the ring & pinion? The differential case including the spider & axle gears, and differential bearings? Or something else?
