Door Ajar Light
Old Mar 9, 2002 | 12:02 PM
bhdunbar's Avatar
bhdunbar
Door Ajar Light
I have read here that the door ajar light comes on b/c of the door sensor and that you just need to use a little wd-40 on it....my problem is I can't find the sensor...can anyone help me out here the light is very annoyning.
Old Mar 11, 2002 | 11:27 AM
white99's Avatar
white99
Door Ajar Light
It is in the area that your door latch is. I sprayed around the whole latch about 6 months ago and everything has been normal since then.
JimP
Old Mar 18, 2002 | 09:17 PM
bobward737's Avatar
bobward737
Door Ajar Light
Put the little red WD-40 hose nozzle in and around the door latch mechanism. Give it a good soaking..... Does the trick!!
Old Mar 29, 2002 | 09:40 AM
adelyser's Avatar
adelyser
Door Ajar Light
Man, you guys are awesome. I hosed down the latches for all my doors, and the ajar light and autolocks all work, everytime without a hitch even!
Thanks for the help.
Old Mar 29, 2002 | 09:38 PM
Rusty66's Avatar
Rusty66
Post Door Ajar Light
Based on my experience, I suspect that this little problem can affect F-series light duty Ford Pickups and Expeditions. At about 45,000 miles, my '97 F-250 light duty pickup developed the door ajar light remaining on symptom...Dome lights would not go off...horn honked twice in quick succession when the lock button was pressed twice on the keyless remote entry fob. I sprayed a good amount of LPS 2 lubricant into the door latches. This immediately fixed the problem. Evidently, the mechanism for the door ajar sensor is in the door latch. Tonight, our '97 Expedition with 50,000 miles exhibited the exact same symptoms. Got out the trusty LPS 2 spray lubricant, doused the latches, and immediately rectified the problem.
I wonder if this fix will ever make it to an official TSB? Hope that this string of posts helps other owners protect their financial interests.
This is a great consumer forum to learn about common problems and simple fixes.
Old Mar 29, 2002 | 10:49 PM
kwb377's Avatar
kwb377
Door Ajar Light
My '99 Ranger also had this problem. So far it hasn't shown up on my Xpy.
Old Mar 30, 2002 | 01:31 PM
troy221's Avatar
troy221
Door Ajar Light
Brenda Lamka
Feb 21, 2014 09:58 PM
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
Jamie Arceneaux
Mar 16, 2013 09:05 AM
calibob
1997 - 2003 F150
Dec 27, 2008 01:47 PM
hush210
1997 - 2003 F150
Mar 19, 2008 06:24 PM
