So I was building my own cyberspace truck and noticed that the highest rear end ratio I could go with a dually was 3.73. The other options I saw were a 3.31 and a 3.55. Is this true? Is this the solution to increase mpg? A diesel truck with a 3.31 or 3.55, seriously? What about those of us that want to tow something? They also upped the 5th wheel tow capacity with the 3.73. How can they let you tow more when nothing changed? Even the 450 is stuck with a 3.73. Please tell me I'm wrong.
Well after doing some more digging it seems there is contradictory info on their web site. When I build a 450 it shows the 4.30 as an option but under the towing section it isnt an option for the 450 with the diesel.
Take a look at the gear ratios in the transmission before you make any final verdict. I don't know what they are, but having 6 gears to play with can give you more of a spread than you might think.
When I ordered my truck I was told I only had the option of 3.31 gears due to one of my options I picked (not sure which), I could pick either Electronic locking or Non Limited slip. I took the Electronic Locking option and I hope I am not going to be disappointed with the 3.31 gears on my new truck.
you can always switch those gears out on the aftermarket if they don't work. I have been playing with the website as well and encoutered the same thing.
Very true, I will probably end up going to 4.10's once a lift kit comes out for the 2011's. That way I can put it on some 37 inch tires for the desert.
With the 6.7L, 3.55 e-locking is only available on the F-250 if you get the 4x4 option and one of these: heavy service front suspension, heavy service for pickup box delete, snow plow prep or camper package.
I got the 3.31 e-locking on my truck.
I am still a little apprehensive about it but we'll see.
Like senix said, they can be swapped later except a little more costly with a 4x4.
