Ease The Pain
Old Apr 12, 2010 | 05:15 PM
BDawg171's Avatar
BDawg171
Ease The Pain
These trucks are the easiest, yet hardest trucks to work on!!
How does everyone work under the hood? I cant reach anything without laying across the radiator or engine and that is not comfortable. I've tried a small step ladder and basically lay across the engine to work on stuff. IT HURTS!! Im 6'1" and my truck is a stock suspention F250. I am in the process of replacing valve cover gaskets and may have to remove the manifold for other reasons. Short of taking off the fenders, hood and all that, is there an easier apporach?
Any suggestions, throw them out there!!! Matress pad, blankets, sitting on the radiator, etc. Perhaps it's another one of the nuances of owning these beauties...
Old Apr 12, 2010 | 06:24 PM
berry1234's Avatar
berry1234
I agree. My back kills after working on my truck. They have tire ladders like this.
But the problem is the hood hinge is in the way.
I also saw a ladder type deal that you lay on your stomach and it goes over the engine area, but you wouldn't have much leverage and your shoulders would get tired.
You almost have to sit in the engine compartment.
Old Apr 12, 2010 | 06:30 PM
Furyus1's Avatar
Furyus1
Last time I pulled my intake off, I sat on the radiator with my legs straddling the engine...
I have one of those tire step things - I got mine at Fred Meyer - It's adjustable. Works well for some things but you gotta lock the e-brake otherwise, you'll be rocking the truck back-n-forth...
Old Apr 12, 2010 | 07:41 PM
CalebJns's Avatar
CalebJns
Sitting in the engine compartment works for some stuff...still not the most comfortable, but can work...I have an aluminum work bench that works, but still the same thing...bending over and stretching...I have actually thought about digging a pit, so I could just sit or lay on the ground prostrate and work...don't think the wife would go for that one though!
Old Apr 12, 2010 | 07:49 PM
Kalve's Avatar
Kalve
When I have it in the garage an need to get something on the front of it I just use a ladder to lean across it or just step up on the front bumper. For me its easy to work on 5'7 135lbs an getting under it is easy with a creeper an have the front up on a set of ramps. The thing I like bout it is there is plenty of room under the hood to move around with just a 360 in there.
Old Apr 18, 2010 | 12:38 AM
wdfp's Avatar
wdfp
I had some 1" square tubing lying around so I built me a little stand about a foot high to stand on, could be any height though, 4' wide or so with plenty of depth so I can stand flat foot anywhere on it that works quite well for me..
Old Apr 18, 2010 | 01:10 AM
Broncodawg's Avatar
Broncodawg
Being 6'8" helps out a bunch. add a steel milk crate and there's no stopping me. Haha.
Old Apr 18, 2010 | 10:11 AM
berry1234's Avatar
berry1234
The problem with stools/steps for me is when I lean in over the engine, they tend to slide out away from the truck.
Old Apr 18, 2010 | 11:27 AM
1977F250Custom4x4's Avatar
1977F250Custom4x4
You guys are doing it all wrong.
Old Apr 18, 2010 | 11:41 AM
Tees77f150's Avatar
Tees77f150
Thumbs up
This is what I did when I pulled my 300 out. It just so happened the district attorney's office called and at the end of the conversation, they ask what I was doing on my day off, I told them they wouldn't believe me if I told them.
I usually use a small wooden three step ladder, but sometimes it kicks out and I fall on the radiator support which usually causes a few four letter words to eminate from the garage.
This usually tells me it is time for a drink so I go to my old Pepsi machine I have in the garage, drop 50 cents in and have a cold beer!
Old Apr 18, 2010 | 08:04 PM
twisted84toyota's Avatar
twisted84toyota
Well brother I feel your pain I'm 6'8" and my F250 has an 8" lift and 38.5's.................I usually have a SMALLER friend help out OR I'll use boat cushions and whatever padding I can use..............
Old Apr 18, 2010 | 08:30 PM
johnboy427's Avatar
johnboy427
I highly recommend 1977F250Custom4x4's method if you have the radiator out, I also use a 12" by 18" limestone block that I can stand on and it doesn't kick out. I have also been known to sit with my feet on the front crossmember and my butt on the radiator support but that get to be a pain in the a$$ after a while. Makes me really enjoy working on my Comet, but when ever I am crawling around on the ground under the Comet that make s realize how much I like working on my truck.
-John
Old Apr 18, 2010 | 08:58 PM
montana_highboy's Avatar
montana_highboy
You just gotta man up and jump on in there and have at it, these trucks weren't built for sissies, if you want easy wrenching conditions buy a Prius or something lol.
Old Apr 18, 2010 | 09:07 PM
bmuhlbach's Avatar
bmuhlbach
on my 78 F250 4x4 pulled the radiator and stood on the leaf springs or flat on the ground .
Old Apr 18, 2010 | 09:28 PM
JRon's Avatar
JRon
I have about a foot slope in the door way of my shop, so I pull the front bumper up about even with the door way and stand right inside the door way of the shop and it puts me about a foot taller. Works great. unless its raining. I'm about 6ft by the way.
Josh
