'97 EVAP system
Old Jan 22, 2002 | 03:25 PM
xp8103's Avatar
xp8103
'97 EVAP system
Old Mar 30, 2002 | 01:01 AM
troy221's Avatar
troy221
'97 EVAP system
I have a '97 Expedition that is running terrible. The code is P0443 EVAP VMV circut fault. Has anyone else had this problem? I checked the charcoal canister and didn't find any cracks in it. I saw someone else on this site fixed their rough engine by replacing the fuel cap. My next step will probably be the Vapor management valve. Can anyone help?
Old Mar 30, 2002 | 10:08 AM
jcb67's Avatar
jcb67
'97 EVAP system
Is the idle rough? does it fluctuate?
John B.
1998 Expedition 4.6
Old Mar 30, 2002 | 01:31 PM
troy221's Avatar
troy221
'97 EVAP system
It does idle rough. But I notice it the most when I'm accelerating. If you keep it at a steady speed,it's not as bad,but when you give it gas the check engine light starts flashing. This is most likely from the #4 coil,the code for #4 missfire also showed up in the scan. I was told by a mechanic that when the light flashes it is a dead miss. But I don't think this would affect the EVAP system. It has stalled several times,usually it's when you take off after sitting in drive with your foot on the break for a while. I never had that problem when it was missing on another cylinder.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
Roachfood
Mar 11, 2002 10:21 PM
