Automatic 4 wheel drive
Old Apr 12, 2010 | 07:16 AM
jtorsey91's Avatar
jtorsey91
i don't know about anyone else but im not the biggest fan of auto 4wd. ill be in the mud or something and i can hear and feel it kicking in. i would love to be able to make it so its just RWD unless i put it in 4x4.
Old Apr 12, 2010 | 08:10 AM
ncranchero's Avatar
ncranchero
Just Google or search the term " Explorer brown wire mod" and you'll get an eyefull of links to do what you wish.
This is probably the most comprehensive: http://www.explorerforum.com/forums/...d.php?t=149388
Old Apr 12, 2010 | 08:35 PM
jtorsey91's Avatar
jtorsey91
nice! im probably going to do this when it gets a little warmer out. thank you!
Old Apr 14, 2010 | 12:57 PM
blustang6614's Avatar
blustang6614
02 explorer
what year is your explorer? I have an 02 and I have run into this problem. Mine mainly is i went up slightly higher in tire size and the auto 4wd does not like the extra inch or so so when getting up to speed to say get on the highway it bucks as if saying the tires are slipping. Anyways I found the disconnect for the wire harness under the glove box and disconnected from the 4 wheel drive control module. This puts it in 2wd until you plug it back in. This is less than ideal but if you dont use 4wd often its an easy way to bypass any modifications. I spoke with a ford mechanic and they stated it would not cause any problems doing this and so far going on a year of doing this I have seen no problems. That is if you can put up with the 4wd lights flashing on the dash periodically. Hope this helps...
Old May 26, 2010 | 10:12 AM
jtorsey91's Avatar
jtorsey91
i finally was able to get it done. it works great!!! tires don't spin on dry pavement but on dirt its sick. everyone with automatic 4wd should do this.
joeskeeter
Feb 21, 2008 10:23 AM
mikedeason
Apr 2, 2007 10:38 AM
nobull4x4
Jan 23, 2005 03:55 PM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
4x4x4x4
Sep 30, 2002 03:55 PM
