hi-beam switch burning up
Old Apr 12, 2010 | 03:29 AM
mebe2k's Avatar
mebe2k
on my 88, when i have the headlights on, i have a hot-spot on the steering column, and i smell something burning.. headlights still work..is it just the turn signal/hi-beam switch, or the turn signal hi-beam switch and wiper switch, are they all integrated? my truck is now going through the electrical problem phase of it's life..just had to replace the t/s flasher..not too bad getting 22 years out of one of those, also had a couple bulbs in the instrument cluster burn out..and It eats radios for some reason.. every radio i've put in there has started screwing up in one way or another.. i've checked the heck out of the wiring for shorts, and i have grounded the crap out of the deck..
Old Apr 12, 2010 | 11:11 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Look in the owners manual for the location of the headlamp relay. It should be in the fuse cluster. That might be the cause. The relay supplies high amps to the lights so the headlight switch does not have to carry a high amp load to power the headlights.
Old Apr 12, 2010 | 12:55 PM
KhanTyranitar's Avatar
KhanTyranitar
Disregard the above post. The switch still carries the full load of the hadlights. The solution is to install a headlight relay kit. The kits are based upon the type of bulbs your setup uses. So for example, if your vehicle were to use a 9007 bulb, you would get a harness that is made for the 9007. These kits take the electrical load off the switch, to the switch only acts as a trigger. It has the added benefit of making the headlights brighter.
Old Apr 12, 2010 | 02:35 PM
5.0B2's Avatar
5.0B2
To answer the question you asked - its called the multi-function switch and it includes the items you mentioned and the emergency flasher switch.
Old Apr 15, 2010 | 12:52 AM
mebe2k's Avatar
mebe2k
sorry for the late reply..been busy at work..I figured it was the whole switch assy... i need to replace it soon.. now the lights are starting to blink on and off every now and then..atleast the burning smell stopped.. i guess whatever was burning inside that switch is fully toasted now..still have the hot spot on the column..thanks for the help
Old Apr 15, 2010 | 04:17 AM
fl1a's Avatar
fl1a
LMC truck carries a relay kit that is simple to install. The burning in that area will come back otherwise. You might have some spade lug sockets ready to repair your connections to the multifunction switch.
Wadsworth5
2009 - 2014 F150
Nov 24, 2022 04:23 PM
troverman
Oct 3, 2018 09:01 PM
TheRedlines
23
Jan 7, 2017 11:50 AM
AndrewZimmermann
Electrical Systems/Wiring
Sep 29, 2014 10:08 AM
dessmo
Nov 25, 2012 12:21 PM
