fuel pressure problem, need help !!
Old Apr 12, 2010 | 03:00 PM
guzzle92's Avatar
guzzle92
Originally Posted by Thomasy
I believe that the in fuel line is on the bottom of my fuel filter housing and the return line is on the top. If I remove the return fuel line from my fuel filter housing will that expose the fuel pressure regulator or is it removed from inside the fuel filter housing?
The FPR housing is secured to the fuel bowl with 2 torx bolts externally. You have to disconnect the return line and remove the two screws. The spring pressure is substantial so remove the screws evenly, a little on one side and then the other so you do not put undue stress on the housing bolt ears.
Like Dan said, check you in-tank screens first.
Old Apr 12, 2010 | 04:52 PM
ChunderDownUnder's Avatar
ChunderDownUnder
I to strongly suggest the intake mod.
heres all my bits
this is what it looked like
Now you dont have to go this far but this is the filter I used
and heres Guzzles detailed instructions
Welcome to guzzle's In-tank Hutch Mod Web Page
Old Apr 14, 2010 | 11:50 AM
Thomasy's Avatar
Thomasy
You guys ROCK !!!
Cleaned the two screens in the canister. Don't know how fuel could even get through them. Want to thank Chris for the suggestion and especially the picture. A lot of good suggestions and information. My truck now runs great again.
Thanks again !!
Frank
Old Apr 14, 2010 | 12:22 PM
Kwikkordead's Avatar
Kwikkordead
Thank you for getting back to us and letting us know.
Any other questions you have, don't hesitate to ask.
Old Apr 14, 2010 | 01:01 PM
KYFarmBoy's Avatar
KYFarmBoy
I recently had the same problem with my 2000 F-350 DRW. The trash in my tank was the tank lining. It was flaking off and I finally had to replace the tank. I realize this was an extreme case but thought it would be of interest.
Old Apr 14, 2010 | 05:55 PM
HD Rider's Avatar
HD Rider
If that ever happens to mine, I'm going with a 68 gal Titan tank.
Old Apr 14, 2010 | 08:02 PM
ChunderDownUnder
Good work m8, glad you got it sorted
nossliw
1499
Sep 23, 2019 02:38 PM
navistarnut
Oct 19, 2018 01:53 PM
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
menchris
Sep 23, 2014 07:12 PM
Paco_Jones
Oct 11, 2009 07:14 PM
