2002 7.3 No Start
Old Apr 18, 2010 | 08:34 PM
00SvtLightning's Avatar
00SvtLightning
Originally Posted by F350-6
The IPR numbers look in spec. The problem is I don't know if it's showing the actual duty cycle or if it's just showing what duty cycle the PCM is calling for. If blocking off each head individually gives you the same 200 psi, then you've either got an IPR or an HPOP issue. (or you're almost out of oil)
Is there anything visual wrong with your HPOP or do you have any oil leaks? Is the tin nut snug on the back of the IPR?
crank seal leaks a little, nothing leaking in the hpop system that i can see.
ya the nut is tight and its a new ipr, did the same thing with the old one. I am probally thinking its going to be the pump by just the way the truck gradually starting loosing power until it just quit running. it went a few miles and just got slower and slower.
Old Apr 18, 2010 | 08:40 PM
00SvtLightning
i was going to check the bolt/nut on the end of the hpop shaft. i guess it could have gotten loose and the pulley is slipping the shaft. just a thought, the truck has had a reman hpop on before you can see the sticker but it was done before dad got the truck.
Old Apr 18, 2010 | 08:43 PM
F350-6's Avatar
F350-6
Well it's pretty unusual for the HPOP to just die without something obvious falling off or leaking, but I guess anything is possible. Unless you screwed up the o-ring installation on both sides, then good oil in the reservoir, new IPR and still having a low ICP would make me look at the HPOP too.
Joey at Terminator Engineering has a nice modified 17 deg HPOP or Bob at Dieselsite has the Adrenaline. The prices are pretty reasonable and it's an upgrade over stock.
Keep us updated on what you find. If one of those guys rebuilds your HPOP, I'd be curios to find out how the pump wore out with no obvious signs of an issue.
Old Apr 18, 2010 | 08:53 PM
00SvtLightning
i got a new one locally for 410$ from full force diesel great bunch of guys he let me take it and told me if i used it i could pay him for it.
Old Apr 18, 2010 | 08:57 PM
F350-6's Avatar
F350-6
That's an even better deal. Someone local willing to work with you is worth it's weight in gold. If the new one fixes your problem and they don't want the old one back as a core, I hope you tear into it to try and figure out what went bad.
Old Apr 18, 2010 | 09:06 PM
00SvtLightning
will do thanks for the help
diy
47
Sep 29, 2017 12:25 PM
RustOrBust
Aug 3, 2017 08:25 PM
Zagato78
29
Feb 5, 2017 10:12 PM
jtharvey
19
Apr 15, 2012 03:44 PM
Pocket
57
Sep 22, 2010 11:38 AM
