first timer doing engine rebuild.
Old Apr 11, 2010 | 03:09 PM
sam71sportcustom's Avatar
sam71sportcustom
Smile first timer doing engine rebuild.
so i bought a 71 250 , vin says 360 but stroke says 410 428. but any who just want to know what i need to know as far as what to do, what not to do. any help would be most helpful . thanks
Old Apr 12, 2010 | 11:25 AM
385seriesHemi's Avatar
385seriesHemi
First off, have patience. Make sure you have the correct tools to disassemble and assemble the engine properly. How will you be having the components cleaned after you have taken it apart?
Old May 2, 2010 | 10:32 AM
sam71sportcustom
my nephew has a hot tank at school and it wont cost me thing. i got it out and the intake and heads off and its a 428.
Old May 5, 2010 | 09:53 PM
mark a.'s Avatar
mark a.
So it has the hatchet weight on the crank snout and a counterweight on the flywheel/flex plate ? 428's were external balance.
Old May 5, 2010 | 10:42 PM
393STROKER's Avatar
393STROKER
Anything mechanical should be inspected for damage or wear.Realistically an old Fe is probably pretty worn out by now. On my `71 F250 I tore it down and had the block checked for cracks.It was good but needed bored out.The heads need totaly rebuilt.
1 disassemble
2 clean
3 inspect
4 repair/replace
Old May 8, 2010 | 10:53 PM
Moto Mel's Avatar
Moto Mel
That depends on the production year of the engine. The 428 CJs were externally balanced while the early 410s and 428s were internally balanced.
Schickel
WTB - Ford Trucks & other vehicles
Nov 8, 2013 09:53 PM
jaye
May 22, 2009 10:16 AM
jsmith71
Dec 7, 2004 12:04 PM
Ray71
1978 - 1996 Big Bronco
Jun 15, 2004 06:04 PM
Goodold71
Offroad & 4x4
Jun 6, 2003 03:25 PM
