Offroad & 4x4
HELP!!
Old Apr 11, 2010 | 03:03 PM
07blkf250's Avatar
07blkf250
HELP!!
HELP! I installed a 2" spacer on top of my 6" Pro Comp Springs and now I can't get the track bar to line up with the bracket so I can tighten it down and finish the job. Any ideas? Am I going to need to purchase a new adjustable track bar?
Thanks
Old Apr 11, 2010 | 03:58 PM
alpha/omega's Avatar
alpha/omega
either that or build a new track bar drop bracket to match your lift.
Old Apr 11, 2010 | 04:04 PM
alpha/omega
double post
Old Apr 11, 2010 | 06:08 PM
ibleedblue1385's Avatar
ibleedblue1385
or take the spacers out...
Old Apr 11, 2010 | 06:20 PM
alpha/omega
unfortunately that wasnt one of his options.
silly newblets.
Old Apr 11, 2010 | 07:53 PM
06silvercrew's Avatar
06silvercrew
Have someone turn the wheels while you hold the track bar and slip the bolt in when it lines up.
Old Apr 12, 2010 | 10:35 AM
Prozon's Avatar
Prozon
Yeah.. just remove the spacer, whats the point?
Old Apr 12, 2010 | 10:43 AM
alpha/omega
wont that put the suspension in a lateral bind pulling the entire suspension towards the driver side?
Old Apr 12, 2010 | 10:53 AM
Prozon's Avatar
Prozon
Yeah, if you pull it to one side to get it to line up, your gonna have it bolted up and staying in that position.
But other then removing the spacer, I think the only option would be to build a new bracket or get a new trac bar.
Old Apr 12, 2010 | 11:03 AM
alpha/omega
see post #2 highspeed!
Old Apr 12, 2010 | 11:21 AM
Prozon's Avatar
Prozon
Thats what I was referring to. I wouldn't think to put a new bracket, i'd just get a longer trac bar.
Old Apr 12, 2010 | 12:00 PM
captain p4's Avatar
captain p4
He just goes through all the threads and repeats the best looking answer he sees, don't mind him.
But yes, turning the wheel like that will pull the axle over driver side. I'm thinking it won't be a huge difference and most likely a non issue.. but all of that depends on the angle of the bar as to how far over it will pull the axle.
Old Apr 12, 2010 | 12:22 PM
75F350's Avatar
75F350
Dont forget the drag link.
Angles and length will be an issue here too.
Old Apr 12, 2010 | 05:03 PM
06silvercrew
My front end geometry is spot on, if I take my trac bar loose it wont "line right back up" the truck is going to lean one way or the other just a hair. A 2'' spacer wouldnt make a HUGE difference. Take a stock coil sprung SD truck and take the trac bar loose IT WONT line right back up. It will take some "finess" and IMO best way to do this is just have someone turn the wheel slightly while you slide the bolt in when it lines up. Now all this is just assuming its just a little off, now if we are talking 3'' yes you will need to rethink your setp.
Hoothooters
Nov 1, 2016 05:11 PM
Jimmygunz3
Sep 21, 2012 11:24 PM
afonda
May 30, 2012 07:34 AM
my79f
Oct 5, 2006 12:36 PM
thesprocket26
Offroad & 4x4
Aug 24, 2004 08:53 PM
