no oil pressure
Old Apr 22, 2010 | 08:09 PM
hotrod91174's Avatar
hotrod91174
no oil pressure
I have a 88 f-350 w/460 fi. engine is supposed to be a Jasper reman w/about 26 -28 thousand on it. my problem is that it lost oil pressure while driving( at least I believe, lifters got real noisy.gauge was not working at the time ). I pulled the pan and put a new high volume pump in it , pickup screen was clear w/no blockage. got it back together and still no oil pressure( have manual gauge on it ). lifters are still noisy. bottom end of engine seems ok no knockig ,bearings looked good, engine is clean as could be on inside not a spec of sludge at all.tried the oil filter adapter nothing clogged, and tried a second adapter to rule out. second time around on new oil & filter( vavoline 10w-40 & motorcraft filter )still not reading on gauge & lifters still noisy. do not know where to look next as I am getting frustrated! any help would be great! sorry for the long post but wanted to get as much info down as possible. thanks , Brandon
Old May 1, 2010 | 06:02 PM
phatjack81's Avatar
phatjack81
Sounds like maybe a plug or a restrictor inside the motor backed out or maybe a loose or bent pushrod let a lifter pop up out the hole.
GT-Rex5.0
Aug 23, 2011 08:19 PM
zaaac
Jan 31, 2010 02:55 PM
FourPointTwo97
1997 - 2003 F150
Aug 7, 2007 05:42 AM
bdunegan
Apr 17, 2007 07:46 PM
ADSf100
Mar 28, 2003 04:59 AM
