Carb CFM?
Old Apr 11, 2010 | 02:10 AM
wolfie10's Avatar
wolfie10
Carb CFM?
Would an older ('67) carb have more CFM than a '80 carb? Or would there be no differece at all between the 2?
Old Apr 11, 2010 | 02:25 PM
F-250 restorer's Avatar
F-250 restorer
What type (model and #) are you speaking about?
If you have the model and number, google it, and you'll probably find the info you want.
Old Apr 11, 2010 | 05:36 PM
wolfie10's Avatar
wolfie10
The tag is gone off the '80 carb so I don't know what to do
Old Apr 11, 2010 | 06:12 PM
85e150's Avatar
85e150
No meaningful difference. Power ratings were very similar once you get through the change from gross to net and any smog motor changes made.
So if you bolt the old carb on the newer engine, don't expect a power increase.
Old Apr 12, 2010 | 01:52 AM
flipklos's Avatar
flipklos
There is no great fundimental difference in CFM between the ford YF type carbs. They are all about 170 CFM.
Old Apr 12, 2010 | 09:56 AM
AbandonedBronco's Avatar
AbandonedBronco
The only difference you'll really find is that you'll be able to more easily run the newer engine without smog equipment with the older carb. The 80's carb will run slightly lean without it all hooked up due to it being calibrated for emissions.
Other than that, they should be very much the same as far as flow rates.
Old Apr 13, 2010 | 08:52 PM
wolfie10's Avatar
wolfie10
Well I think I will just keep the '67 carb on the '67 motor. we don't have smog regulations here so I don't have to worry about that. That's why I'm putting an older motor in my truck. No smog.
Old Apr 13, 2010 | 10:43 PM
85e150's Avatar
85e150
Generally, when you change engines, you must pass emissions requirements for the newer of the vehicle or the engine.
If you put a new engine in a old car, who's going to know, since it's exempt from testing.
If you put an old engine in a newer, emissions test required vehicle, and think you'll just be able to wave them off by telling them it's a '67 engine, you have a surprise coming.
Your engine change will come under "Emissions Device Tampering" unless you bring it up to 1980 spec (if that is the year of your vehicle)
Nevada Emissions Control Program
Unless you are in an exempt area---hope you are.
