smaller diameter air cleaner
Old Apr 10, 2010 | 11:47 PM
lasthighboy's Avatar
lasthighboy
does anyone know of a smaller diameter air cleaner (any application that is readily available) that will fit on an edelbrock carb? Im using a factory air cleaner housing on a 460 in a 75 f-150 4x4 and the back of it hits the pinch weld on the firewall. Chevy air cleaners require a spacer to clear the choke components so i dont want to go that route. I do want to run a fully enclosed housing. a taller filter would not be a problem, just need smaller diameter.
Old Apr 10, 2010 | 11:56 PM
4x4cody's Avatar
4x4cody
my motor is a 360 but i run a smaller air cleaner.. only bcuz its all i had in my shop and i didnt want to go buy a new one since this one works fine and was new
Old Apr 11, 2010 | 12:19 AM
tinaheels's Avatar
tinaheels
nice valve covers 4X4CODY
Old Apr 11, 2010 | 12:20 AM
lasthighboy
that is an open element. i am looking for a fully enclosed factory air cleaner with a snout. it is on a mud truck.
Old Apr 11, 2010 | 01:23 AM
montana_highboy's Avatar
montana_highboy
Buy an offset air cleaner adapter, jegs or summit should carry them.
Old Apr 11, 2010 | 01:50 AM
4x4cody's Avatar
4x4cody
they're "cal-customs"
ohh i see what your talking about now.. sry
Old Apr 11, 2010 | 02:03 AM
pat67shorty's Avatar
pat67shorty
Some of the 70's car 302s had a smaller factory air cleaner.
Old Apr 11, 2010 | 08:22 AM
lasthighboy
Thank you Pat. Does anybody know of any other options? Any application will work. I really dont want to run an adapter or i would just use a Chevy pickup air cleaner. They are really easy to find.
Old Apr 11, 2010 | 12:13 PM
75F350's Avatar
75F350
How about getting the filter inside of the truck?
Old Apr 11, 2010 | 01:04 PM
lasthighboy
i thought about that but i have seen them backfire and light up the whole inside of the cab with a fireball. Id rather try to leave the fire under the hood and just have it pull air from inside the cab. i was going to fab up a snorkle to go through the firewall.
Old Apr 11, 2010 | 01:05 PM
lasthighboy
where did you get the snout you have on your carb? id still have to have something like that anyway.
Old Apr 18, 2010 | 08:58 PM
lasthighboy
bump to top
mwoj
May 21, 2015 05:24 AM
johnfin1
23
Dec 22, 2014 09:55 PM
LuckyHorse426
Air Intakes, Air Filters & Ram Air
Oct 14, 2014 08:31 AM
trepid94
Oct 11, 2014 09:40 AM
