Any Ideas?
Old Apr 9, 2010 | 10:50 PM
almightyo0o's Avatar
almightyo0o
Any Ideas?
My truck was driving fine and out of no where I pulled in my sister's driveway taking my nephew home the truck died check engine light came on and battery light came on. I tried to start it it wouldn't start so I called my dad up to come tow me home. On our way I figured I'd try to start it so I did and it kicked over then died instantly and did it like 4 times. My battery died fairly quickly so much that my hazzards just staye solid and wouldn't flicker. I thought either the battery terminals could be bad but then thought if that was the case the truck wouldn't try to kick over. I figured the fuel pump but it wouldn't have almost started towing it home... Any Ideas?
*Edit*
Its a 2000 Ranger 4banger RWD and I've been having abs problems with it...
Old Apr 10, 2010 | 12:34 AM
g_k50's Avatar
g_k50
dead alternator / battery
Old Apr 10, 2010 | 09:37 PM
sfcwoodret's Avatar
sfcwoodret
Battery has dead cell.
Old Apr 10, 2010 | 11:09 PM
MikeB 88's Avatar
MikeB 88
Bad battery plus bad alternator. I had a cell go bad once on me. As long as the truck was running, it stayed running. Once I shut it off, it was time to change the battery.
Old Apr 11, 2010 | 05:47 PM
almightyo0o
So I went out to my truck today without messing with it. Turned the key it started right up and ran fine. I shut it off went to start it back up and it wouldn't start. I changed the terminals and put a new battery in it and it tried to turn over once then it stopped. I tried to turn the key again and it was turning over but wouldn't start. I did it about 3 times then it was like the battery was draining right down to nothing and wouldn't start. I checked the oil and it is low but I don't see that being the reason it wouldn't start? Someone told me that a sensor would tell it not to start when its that low on oil is that true?
Old Apr 12, 2010 | 12:45 AM
g_k50's Avatar
g_k50
Check voltage on battery.
Old Apr 13, 2010 | 02:38 AM
silverranger1992's Avatar
silverranger1992
Perhaps if it is a sensor problem, add oil and try again. I'm hoping that your engine isn't seizing up.... And like gk said, check your battery even though it is new.
Old Apr 13, 2010 | 05:54 PM
almightyo0o
I sprayed some ether (quick start stuff) in and it started right up then died a few seconds later so I believe its the fuel pump I'm going to drop the tank one day this week and look at it more...will update when I do...
JJock
Feb 23, 2015 04:49 PM
jtlinn1975
16
May 7, 2014 08:20 PM
chrisvan09
Aug 1, 2011 12:48 PM
Mian777
Jun 15, 2011 10:04 AM
Mech 1990
1997 - 2003 F150
Jul 12, 2005 11:04 AM
